Rattle
Old Jun 17, 2022 | 09:44 PM
Haitianluv's Avatar
Haitianluv
1st Gear
Default Rattle
My car makes a rattling sound in the morning when I started it sounds like something is rattling in the driver side engine compartment sounds like a old diesel motor or it sounds like just something loose rattling but it cycles like the AC unit cycles and stops when the car warms up I cannot figure it out
Old Jun 17, 2022 | 10:24 PM
DerrickM's Avatar
DerrickM
The fuel injectors are noisy on these cars--could it be that? Can you hear it in the car with the windows up?
Old Jun 18, 2022 | 12:45 AM
Likely the exhaust shields, as the cars get old the screws that hold them rust and they can move around slightly. Older motor mounts magnify the noise
Old Jun 18, 2022 | 04:05 AM
Anfanger's Avatar
Anfanger
It could be the engine rattle, it is common on these engines.
Old Jun 18, 2022 | 06:22 AM
swfla's Avatar
swfla
It's just an engine rattle made up of fuel injectors that stop tapping when warm. Nothing to worry about.
Old Jun 20, 2022 | 03:27 PM
sktn77a's Avatar
sktn77a
What do you mean by this? Cycles on and off?
Old Jun 20, 2022 | 07:15 PM
Mythicalni's Avatar
Mythicalni
https://www.clublexus.com/forums/att...0031l-0516.pdf
This isn't that big of deal because the rattle is low oil pressure to the tensioner. After driving 100 miles in 84°F heat at idle with AC on/off the rattle will come back. I switched to 5-30 with a heavy oil stabilizer its been keeping the tensioner rattle at bay. The oil stabilizer keeps the oil from breaking down in high heat. I drive 09 LS with 254xxx miles and commute 200 a day. I know this vehicle very well!
I'm planning on replacing the chain and all tensioners at 300xxx miles just because this rattle has always been on my mind.
I DO NOT RECOMMEND 5w30 with oil stabilizer IF YOU DRIVE LESS THAN 25 MILES A DAY.
File Type: pdf
Old Jun 20, 2022 | 09:21 PM
The tensioners are self ratcheting with the exception of the chain linking the intake to exhaust cams, unlikely the main tensioners are having the rattle when cold/drained or when the oil is hot.
Old Mar 3, 2023 | 04:39 AM
dan25man's Avatar
dan25man
Haitianluv does it sound like this? See attached. My 2014 has 300k miles on it. I have noticed this sound only on a cold start-up and once it's warmed up it won't make the sound anymore. My mechanic buddy said it sounded like a stuck lifter that is oscillating incorrectly when cold, but then become un-stuck when warmed up. He said that as long as I'm not driving heavy load when it's making this sound it's probably good.
I will say that I added SeaFoam cleaner into my oil last weekend (9 fl.oz.) and since then this noise has gone away. I'd imagine the cleaner un-stuck whatever was making this sound. As previously mentioned by Mythicalni I do plan on moving to 5w-30 and adding in a heavy oil stabilizer when I change the oil this weekend. Hopefully I don't find metal in my oil today....
File Type: mov
Old Mar 23, 2023 | 10:02 PM
diamente's Avatar
diamente
i am having the same issue. https://www.clublexus.com/forums/ls-...l#post11473085
so I should use 5w-30 and put in lucas heavily oil stabilizer? this video says no oil stabilizer. just use heavier oil.
LS460 has VVTI engine, definitely don't use certain type of oil stabilizer
lkb3
Mar 30, 2026 12:02 PM
levinsoy
GX - 1st Gen (2003-2009)
Jul 19, 2021 12:40 PM
ObSCessed
May 20, 2021 08:19 AM
Easterlily
Oct 17, 2019 07:59 AM
underpsi
Apr 18, 2007 02:36 PM
