Erratic heating
Old Dec 27, 2021 | 02:48 PM
Thz's Avatar
Thz
Default Erratic heating
Intermittent fault. Cold from the beginning, then it suddenly wakes up and give 23C. Half an hour later I’m freezing and the temp drops to the point my breath is visible. What can it be? A broken sensor or a door in the heat pack that doesn’t open and close properly?
The 460 is 2008 model.
I’m a poor guy, so I have to fix this myself. Can’t afford any workshop. Here in Sweden they are very expensive.
Very grateful for any tips and tricks!
All the best!
Thomas
Old Dec 27, 2021 | 04:15 PM
Set it to max hot to start with, command it for face only on both sides and see where and how it blows.
Also run a scan to see if it has any actuator codes in the AC subsystem
Old Dec 27, 2021 | 04:36 PM
jmcraney's Avatar
jmcraney
You need to check the level of your engine coolant.
Old Dec 27, 2021 | 04:46 PM
jmcraney's Avatar
jmcraney
You may find some useful information here: https://www.clublexus.com/forums/ls-...-this-bad.html
Old Dec 28, 2021 | 10:39 AM
Thz's Avatar
Thz
Default Thank you all!!!
I’ve just checked coolant. Big hiss and pscht when the cap was loosened. Added 2 dl of coolent. Airpocket somewhere apparently.
now I have warmth and everything works A OK!
Thanks for your help!!!
Old Dec 28, 2021 | 11:27 AM
swfla's Avatar
swfla
Now you need to purge air out of system. Torques nut at top of top radiator hose, remove plastic shield to see it.
Old Dec 28, 2021 | 01:20 PM
Welp that was gonna be my next step so to speak if he found that both sides are doing the same error lol!
Old Dec 29, 2021 | 11:47 AM
Thz's Avatar
Thz
will do! Thx!
Cthopkinsc
Apr 22, 2016 07:35 PM
jlawr
Jul 31, 2015 12:47 PM
cgreenberg
Jun 12, 2010 04:58 AM
JohnnyCake
Jul 2, 2008 06:36 PM
tbrdb0b
RX - 1st Gen (1999-2003)
Aug 13, 2007 07:34 PM
