Headlights useless
Old Nov 29, 2021 | 11:53 AM
Boykie's Avatar
Boykie
What about left to right? I mean you can try reaching etc for up/down ones (eb pic) without taking your bumper off, but l/r ones are deeper inside - bolted in and under HV unit (which also serves as bottom cover) - bottom of the hl. But I don't see how l/r ones can come off/get damaged without some catastrophic hl failure. (that said - perhaps lens are pointing so far down/up that you just don't see l/r initial motion)
Also, if you have airsus - any misalignment/problem with height (wheel) sensors and your car will be in a rodeo position.
Old Nov 29, 2021 | 11:54 AM
460LQ8's Avatar
460LQ8
Yes L/R are working properly. Only U/D are not moving...
Old Nov 29, 2021 | 12:05 PM
Boykie's Avatar
Boykie
That's good. Really narrows it down. I think user manual shows how to unbolt fuse box (RH) and washer tube (LH) to reach backs of headlights without doing a bumper removal.
BTW don't linger on 'hate your car' - you're obviously actively trying to fix it and it is love, not hate. I'm just bitter from all badly cared for cars my eyes had/have to see...
Old Nov 29, 2021 | 12:11 PM
460LQ8's Avatar
460LQ8
Haha, nah it's just this car has genuinely been involved in a lot of ridiculous situations -- sandblasted by sandstorm, someone ran a stop sign and destroyed everything from the front fender to the rear door, debris from a truck dropping in my path on the highway with no room to change lanes, etc.
I still like the car but all the little things that have gone bad I've just gone into keep-it-functional-until-I-leave mode...
My vehicles at home get all the love
Old Nov 29, 2021 | 12:37 PM
Boykie's Avatar
Boykie
BTW falling hard debris from preceding vehicle is I think the worst thing that can happen. It did to me on my last LS4. Was driving from hunter road force wheel balance and was happy and careless. Next thing HUGE chunk of unmelted ice projectile did ruin my day. Torn plastic shields, dents in the exhaust tubes and more. Subframe and suspension survived tho.
Old Nov 30, 2021 | 10:47 AM
BlazeViper's Avatar
BlazeViper
I'd start with the suggested sensor adjustment, the little guy in the picture, not the big sway bar link. You can take it of with a 10mm and lengthen it a bit I think one side is a left hand thread so do be careful as they are aluminum and easy to shear. If you get a AFS off light, you've gone a bit too long and are outside the sensor's range.
No, you're mixing up wheel sensors (mounted on wheels) and leveling actuator. Those have mechanical plastic ball->U-claw attachment inside. I just redid mine so images are vivid in my head... If ball-claw become detached there won't be any errors. There are no leveling sensors inside headlight (except failure sensor and l/r position sensor inside swivel actuators - those WILL light up afs error).
Man, I will try making a pic or two but no promises. My old ones I can demo on are in my warehouse. I might take a drive there later.
If then diagram that the OP saw was for a vehicle that had air shocks then there would be four ride height sensors on each wheel.
Old Dec 1, 2021 | 11:12 AM
460LQ8's Avatar
460LQ8
I was reading about this on another model subforum: https://www.clublexus.com/forums/is-...success-8.html
The motors appear to function after all. There's very little movement, but today when it was dark I was able to see it move down and slightly up again when I started the car. There's just so little movement that it's hard to notice...
Will take off the wheels this weekend to check the sensors...
coolcar
Nov 24, 2020 10:32 AM
GREED777
Jan 15, 2017 08:00 AM
doodlebug
Nov 10, 2016 01:53 PM
lexusben
Nov 29, 2015 11:03 AM
melski415
Jun 19, 2009 07:19 AM
