Transfer case fluid a lifetime fluid?
Old Jun 16, 2021 | 11:59 PM
Zetascry's Avatar
Zetascry
Default Transfer case fluid a lifetime fluid?
Title says it all. I’m getting ready to change out transmission and both front and back differential fluid @ 42k on 2014 AWD Fsport. Is the transfer case fluid lifetime? I hear that stuff has to be oem and also read on this and GX469 forums some use the 75w90 differential fluid in transfer case. Will I have the infamous “shudder” issues if I use Ravenol 75w over the oem magic oil from Toyota ? Lol
Old Jun 17, 2021 | 04:05 AM
Anfanger's Avatar
Anfanger
"Toyota/Lexus lifetime" = 10 years/100k miles. I used Mobil 1 75w90 on mine, it seems to be OK.
Old Jun 17, 2021 | 07:28 AM
Zetascry's Avatar
Zetascry
wait, you used 75w90 in your transfer case?!
Old Jun 17, 2021 | 08:46 AM
Anfanger's Avatar
Anfanger
Yes, there is virtually no difference between 75w-85 and 75w-90. Mobil 1 75w-90 is GL-5 compliant. Also, it is what my local Lexus dealer uses.
Old Jun 17, 2021 | 11:12 AM
Zetascry's Avatar
Zetascry
did you get that photo of specific oils from the owners manual? I thought 75W has different properties compared to a 75W90
Old Jun 17, 2021 | 11:16 AM
Anfanger's Avatar
Anfanger
Yes, it is from the owner's manual page 752.
https://drivers.lexus.com/t3Portal/d...f/OM50B55U.pdf
Old Jun 17, 2021 | 01:26 PM
Zetascry's Avatar
Zetascry
I have a 2014 LS, what year is your car? How long ago/miles did you fill up the transfer case with 75W90?
Old Jun 17, 2021 | 02:12 PM
Anfanger's Avatar
Anfanger
I got 2010 but I believe drive train the same unless you have "F" version.
Old Jun 17, 2021 | 02:17 PM
Zetascry's Avatar
Zetascry
yes, I have the F sport with the AA80F transmission. How’s this make a difference?
Old Jun 17, 2021 | 02:38 PM
Anfanger's Avatar
Anfanger
Get a manual from Lexus owner's website or you use a paper copy. It should be written in it what is the required fluid.
Old Jun 17, 2021 | 02:47 PM
comotiger's Avatar
comotiger
Hi Zetascry,
I have a 2014 AWD (80K miles) and had the fluids changed last August. Check thread below, particularly from post #11 onwards.
https://www.clublexus.com/forums/ls-...iff-fluid.html
My car was running fine but I could feel a slight vibration in the shifter. I was hoping the fluid changes would make things silky smooth. Did not happen. In fact, I sometimes feel there is more vibration in the shifter now. In hindsight, this wasn't money well spent. If your car is running fine now, don't bother with the fluid change. There are cars here going 150K miles without changing the differential and transfer case oils.
Old Jun 17, 2021 | 04:04 PM
Zetascry's Avatar
Zetascry
Yep, found the manual. It calls for 75W
Originally Posted by comotiger
Hi Zetascry,
do you mean shifter ****? I’m actually doing entire transmission flush with Amsoil signature ATF, and the differentials with their sever gear 75W90 stuff which I researched is a great product if you abuse the car. But for transfer case I heard about the shudder TSB being fixed with the newer improved 75W oil which “permanently” fixes the issue.
dude my cars 7 years old with 42K miles and I feel that’s long enough lol
Researched and found out the Toyota WS Transmission fluid is not good with heat, especially in an fsport transmission that’s being abused lol
Old Jun 18, 2021 | 05:18 AM
Doublebase's Avatar
Doublebase
Yeah I would definitely change the tranny, diffs and transfer case fluids. And I think it’s more than fine to use 75W90 in an application that calls for 75W85. I’ve done it many many times for literally 100’s of thousands of miles. No issues whatsoever. No drop in fuel economy, nothing. In fact it probably adds just a slight bit more protection/viscosity.
Kee318
Feb 28, 2020 01:29 PM
RageRacerM
Sep 28, 2019 10:55 AM
lexondubs
25
Jan 31, 2010 12:27 AM
autodriver
RX - 1st Gen (1999-2003)
May 16, 2004 11:53 AM
