breather plugs in our diffs?
Old Mar 20, 2021 | 08:02 PM
GreggyG's Avatar
GreggyG
Default breather plugs in our diffs?
Can someone verify that we have a breather plug, and if I have AWD, are there more in the front diff and the transfer case? Can you confirm that it's part number 90930-03077? thank you
Old Mar 21, 2021 | 09:06 AM
Anfanger's Avatar
Anfanger
Front, rear differentials and transfer case have breathers.
https://www.clublexus.com/forums/ls-...l#post10992235
According to Lexus catalog:
Front differential breather part #: 90930-03224
Rear differential breather part#: 90930-03077
Transfer case breather part #: 90930-03133
It seems that breather part number varies depending on a car model but being same part.
Old Mar 21, 2021 | 07:19 PM
GreggyG's Avatar
GreggyG
Thank you. Any thoughts on interval of changing it?
Old Mar 21, 2021 | 07:42 PM
Flick it a few times and listen if the valve is moving freely, spray cleaner if not.
Old Mar 22, 2021 | 04:11 AM
Anfanger's Avatar
Anfanger
Usually, you do not need to replace it ever unless it is stuck open/close or the rubber seal is worn out which does happen. Test functionally as it was suggested above.
Old Mar 22, 2021 | 05:16 AM
GreggyG's Avatar
GreggyG
Thank you, great idea
flipside909
Mar 12, 2022 09:23 AM
itsokay
Jun 15, 2020 01:00 AM
Zsikd
Feb 16, 2020 09:30 AM
jimbug
NX - 1st Gen (2015-2021)
Oct 10, 2019 10:17 AM
river
RX - 1st Gen (1999-2003)
Apr 27, 2016 06:56 AM
