Front Strut Removal Question and torque specs?
Old Jan 19, 2021 | 12:48 PM
Gumart1's Avatar
Gumart1
Default Front Strut Removal Question and torque specs?
I am in the process of replacing my front struts on my 2014 LS. I followed a couple of videos on Youtube and the process has been pretty straightforward to this point - I have the nuts removed up top, upper control arms removed, steering knuckle out of the way and tied up so brake lines aren't stretched. The strut is loose and ready to be removed.
Now as I try to remove the strut it doesn't look like there is clearance over the lower control arm. I push it upward all the way and try to move it forward but it still needs at least an inch to clear the lower control arm.
I'm sure there is a simple answer but I'm stuck. Please help.
Also, does anyone have the torque specs for the front suspension, for when I button it back up?
Old Jan 19, 2021 | 01:21 PM
lwphat66's Avatar
lwphat66
Did you remove the brake line bracket from the knuckle? With the upper ball joints removed, by grasping the top of the knuckle you should be able to move it out of the way to remove the strut, no?
Old Jan 19, 2021 | 01:36 PM
Gumart1's Avatar
Gumart1
Ahh, got it now. Thank you! I did have the brake line removed. I had the knuckle supported so well that I didn't realize it needed to be pushed downward slightly for the strut to clear. I appreciate the tip. Now if anyone has the torque specs I'll be good to go.
Old Jan 22, 2021 | 07:32 AM
lwphat66's Avatar
lwphat66
Sorry for the late reply but was just wondering if you were able to find the torque specs? I haven't used either of these yet, and there is some useful info on these types of sites in this thread: Service Manual? - Page 2 - ClubLexus - Lexus Forum Discussion
https://www.alldata.com/diy/en
https://techinfo.toyota.com/techInfo....toyota.com%2F
I'm currently trying to tack down a set of hard copy repair manuals for my '07 that were last seen somewhere in the South Florida area.....
Old Jan 22, 2021 | 07:46 AM
fwhomeboy's Avatar
fwhomeboy
https://www.ebay.com/itm/2007-Lexus-...temCondition=4
Old Jan 22, 2021 | 08:35 AM
lwphat66's Avatar
lwphat66
Thanks, but I'm hoping to get them for less, plus the set I'm chasing includes the wiring schematics volume. Found the previous shop that owned them but closed and sold them to another shop. Time to put on my detective hat and continue the search.....
Old Jan 22, 2021 | 11:54 AM
Gumart1's Avatar
Gumart1
I wasn't able to find the torques specs but thank you for the link. Wow those prices have gone up a lot on the hard copy shop manuals compared to when I had my '98LS.
Old Jan 22, 2021 | 12:50 PM
sha4000's Avatar
sha4000
Old Jan 22, 2021 | 01:14 PM
Gumart1's Avatar
Gumart1
Excellent, thanks!
Mrbungle11
Jan 20, 2021 12:53 AM
AllinCLE
LS - 5th Gen (2018-present)
41
Jan 1, 2021 08:32 AM
canatto
Suspension
Mar 2, 2020 08:13 AM
Svulexus
May 3, 2018 04:04 PM
ktang235
Suspension and Brakes
Apr 25, 2008 08:37 AM
