Engine Repair/ Replacement Cost
Old Jan 6, 2026 | 03:35 PM
Afeezy's Avatar
Afeezy
Originally Posted by 93MSB
Looks like you have a 2007. If you go the used engine route its best to source an engine from year models 2007-2009.7, they changed the e-vvti gear and ecu after this date. You can buy a newer engine, but you will have to swap the timing chains and components to match the ECU tuning. I'm currently fixing this mistake myself after swapping a 2012 LS460 engine into a 2008 GS460.
If you go the rebuild route, you need to make sure your machinist knows how to work with open deck blocks. They are tricky to machine.
Rebuilt is the safest route to go in terms of starting off fresh and if there's an issue there should be some sort of warranty to fall back on.
its a 2015 GS F Sport. Replacing motor took 4 weeks and $7300. Old motor had 145k. New motor has 90k plus a strong 3 year warranty. Parts and labor.
Old Jan 6, 2026 | 08:54 PM
That has nothing to do with an XF40
Old Jan 6, 2026 | 09:06 PM
93MSB's Avatar
93MSB
Originally Posted by woneal512
So it's not possible to buy a 2013+ engine and put it in a 2007-2009 vehicle?
Its possible, but you cant just drop it in as is.
You have to swap the E-VVTi camshaft timing gear assemblies. Its not exactly an easy or simple job.
edit: just realized the gs350 guy bumped a 5 year old thread, lol
Old Jan 7, 2026 | 02:13 AM
Afeezy's Avatar
Afeezy
I see the confusion. Didn't see a reason to start a new thread.
Old Jan 7, 2026 | 12:58 PM
Lzam's Avatar
Lzam
I would go the used engine route deal with a reputable company and use a professional to install the motor. My brother just did this and spent about $2500 in the entire job.
Old Jan 7, 2026 | 04:35 PM
Afeezy's Avatar
Afeezy
Originally Posted by Gerf
Funny looking LS
😂😂 my bad
NoobExe
Jun 8, 2024 07:21 PM
Mewannalex
Nov 12, 2019 02:02 PM
etivane
Nov 2, 2017 05:04 AM
sam430
May 6, 2009 10:56 AM
