Overheating
Old Dec 21, 2020 | 03:19 AM
macLexy55's Avatar
macLexy55
Default Overheating
My 2008 Lexus LS 460L is overheating and will not accelerate when accelerator pedal depressed. Any suggestions what is the cause and remedy.
Old Dec 21, 2020 | 06:08 PM
jdanielca's Avatar
jdanielca
wrong section, also have you checked your coolant level at all? Does the engine temperature rise steadily as the engine warms up on cold start?
are both your fans working? The engine cooling one, is on the drivers side, next time it rises above 1/2 way point, stop by side of road, leave car running open hood quickly and see if the fan is tuning, it will speed things up if you have taken off the front Black engine trim pieces before hand.
2nd part of the question is hard to say are you getting any error messages on the dash..
invest in some thing like bluedriver and read your codes.
Old Dec 21, 2020 | 09:40 PM
macLexy55's Avatar
macLexy55
Thanks for your reply jdanielca, much appreciated. I will check this out today. Just one thing I would like to add ... this problem happened when my VSC light came on, and has stayed on. I took to an auto electrician and he was the one that said that the overheating could be the problem, but wasn't sure until he takes the car for one day to check the diagnostics and wiring.
Old Dec 22, 2020 | 04:34 AM
Anfanger's Avatar
Anfanger
VCS light sometimes triggers the "limp mode". In the "limp mode", your car will not respond to accelerator almost at all.
Old Dec 22, 2020 | 04:36 PM
jud149's Avatar
jud149
A clogged catalytic converter can also cause this.
Old Dec 26, 2020 | 10:43 AM
macLexy55's Avatar
macLexy55
Just to update you the guys that were kind enough to help me with my small car trouble. Turns out my radiator was leaking. I replaced it with new one and the VSC has now gone out.
Old Dec 26, 2020 | 11:03 AM
sdls's Avatar
sdls
the LS460 isn’t a small car though
Old Dec 26, 2020 | 11:34 AM
fwhomeboy's Avatar
fwhomeboy
What radiator did you get?
https://www.lexuspartsnow.com/parts/...400-38170.html
Old Dec 26, 2020 | 09:24 PM
macLexy55's Avatar
macLexy55
I got the one that fits my car, Lexus part of course
Old Dec 26, 2020 | 09:57 PM
jdanielca's Avatar
jdanielca
For future reference others who encounter similar issues these plastic n metal crimped radiators are all the same, there is no point splashing on Toyota it is not going to be any better if it were that top plastic tube won’t be brittle and breaking. I changed mine to KYB or Kayaba, I think rockauto has osc or something all these are ok and nicely priced. Good luck guys.
Old Dec 26, 2020 | 10:44 PM
fwhomeboy's Avatar
fwhomeboy
I'm sorry, I meant to say where did you get yours from? Was it from Amazon, Rockauto, Denso, Lexus direct? Just curious. Anyway, it's no big deal. I'll find one somewhere. Thanks anyway.
Old Dec 26, 2020 | 11:01 PM
macLexy55's Avatar
macLexy55
Sorry for the misunderstanding 🙄 I got it from Lexus dealer
Arvid
May 17, 2022 10:40 PM
mask0425x
May 2, 2022 07:23 PM
noonzie
Feb 26, 2020 08:42 AM
encore888
Aug 15, 2008 10:48 AM
