Evaporative system, won't pass smog
Old Oct 12, 2020 | 10:04 AM
aslowdodge's Avatar
aslowdodge
Default Evaporative system, won't pass smog
I have a 2014 LS460. Before getting the car smogged I had disconnected the battery. That was 130 miles ago. I run my obd scanner and it says it will fail because the Evaporative system has a warning. It says "vehicle has not completed this test. I know on my LS430 that if you disconnected the battery you had to drive about 60 miles for all the smog related computers would be ready to pass smog.
Anyone have any insight on this?
Old Oct 12, 2020 | 10:07 AM
Anfanger's Avatar
Anfanger
I believe, general guidance is around 100-200 miles. Lights can be set off at any point and not at certain mileage.
Old Oct 12, 2020 | 11:31 AM
aslowdodge's Avatar
aslowdodge
Thanks. Apparently you have to have 1/4 to 3/4 tank of gas and I've kept it full so I'll go for a drive and try that.
Old Oct 12, 2020 | 11:34 AM
Anfanger's Avatar
Anfanger
If I am not mistaken, Techstream allows active testing of certain sensors. It eliminates a need to drive for 100 miles before you know if the problem was fixed. I would suggest to google for related content and see what you come up with.
Old Oct 12, 2020 | 12:37 PM
sdls's Avatar
sdls
Are you getting the same code as you’d get with a loose gas cap?
05RollaXRS
RC F (2015-present)
100
Oct 14, 2021 09:34 AM
krabizz
CT 200h Model (2011-2017)
Oct 9, 2019 01:40 PM
jim7485
NX - 1st Gen (2015-2021)
Dec 13, 2018 10:32 AM
Canoe
Jan 14, 2018 07:30 PM
