Used awd control arms??
Old Oct 2, 2020 | 09:19 AM
stopdrpnro's Avatar
stopdrpnro
Default Used awd control arms??
A quick check on car parts show control arms from +13 awd models with under 60k miles for ~$75. My understanding is the 13+ bushings are revised and hold up better ( could be most 13+ are under 100k though) . Normally I would never consider putting on a used part but I also can't stomach $2k in parts for essentially a few bushings. Am I mad for considering this option??
Old Oct 2, 2020 | 10:41 AM
Anfanger's Avatar
Anfanger
If bushings have no cracks or visible defects and ball joints are in a good shaped, I guess, it is OK to re-use it. Just make sure there is 1 year warranty and the seller is reputable.
Old Oct 2, 2020 | 11:13 AM
LS460Crown's Avatar
LS460Crown
I replaced mine with new factory arms. I have the used arms and they're in ok condition, and I also have the FIGS bushings (brand new) and they can be pressed into the uppers. If you give me a couple of days, I can send you pictures if you're interested in them. These are off a 2010 AWD with air suspension.
Old Oct 3, 2020 | 09:32 AM
stopdrpnro's Avatar
stopdrpnro
After searching again I realized 6 of the 8 arms are available new through beck arnley/rock Auto at reasonable prices. I'm going to roll the dice and buy the last ones used . I'll order them and report back. Thanks for the help
Old Oct 3, 2020 | 01:18 PM
LS460Crown's Avatar
LS460Crown
Sounds like a good plan. Please let us know how they wear. I'm going to find a shop that can press my uppers with the figs bushings so I have those ready to go in another 100k miles.
Old Oct 23, 2020 | 06:38 AM
stopdrpnro's Avatar
stopdrpnro
I lied... Rock Auto has 4 of the 8 arms. Upper forwards and lower forwards . The lower rearward seems to have the same bushing so looking into that.
Old Oct 23, 2020 | 07:24 AM
sdls's Avatar
sdls
beck had the strut rod available for a short while but it’s been out of stock with no restock date for a while
someone should ask them when they will make more
Old Oct 24, 2020 | 10:05 PM
stopdrpnro's Avatar
stopdrpnro
when i called they said the part was on back order till at least january
Old Oct 25, 2020 | 06:46 AM
sdls's Avatar
sdls
thanks for the info! That’s very helpful
Sophall
LX - 3rd Gen (2008-2021)
Oct 5, 2020 07:52 PM
LexusHOG
Jun 4, 2020 04:24 AM
vegasdave
Dec 20, 2018 10:45 AM
LuvmyLS
Aug 10, 2018 05:33 AM
LuvmyLS
Jul 15, 2018 01:39 PM
