Need Some Advice 2010 LS 460
Old Oct 2, 2020 | 08:03 AM
ewil007's Avatar
ewil007
Default Need Some Advice 2010 LS 460
Hey all,
Need some advice on what to look out for on the 2010 LS 460. I have a lead on a clean one with less than 100K miles being sold at a Lexus dealership. I currently own a GX 470 and ripped out the air suspension because it sucks after 10 years. Am I going to be doing the same with the LS? Maybe tear it out and lower it a bit with coilovers? What other common problems am I looking at and can possibly negotiate with the dealership? Thanks in advance as I love hearing from owners before taking the plunge!
Old Oct 2, 2020 | 08:26 AM
Anfanger's Avatar
Anfanger
I can provide you a list of issues I fixed/am fixing on my LS460 since purchasing it around 1 month ago. In between, I got 155k on mine.
- fuel pump repair kit
- intake manifold gaskets
- PCV valve
- engine air filters
- spark plugs and grommets
- valve cover gaskets
- differential fluid (front and read)
- front upper control arm bushings
- cleaned MAFs and throttle body
Old Oct 2, 2020 | 08:30 AM
ewil007's Avatar
ewil007
- PCV valve
Are those items preventative maintenence or did you experience a failure?
Old Oct 2, 2020 | 08:31 AM
Anfanger's Avatar
Anfanger
I forgot to add that I had to fix the valley plate leak. It seems to be a very common issue.
Old Oct 2, 2020 | 08:33 AM
Anfanger's Avatar
Anfanger
- fuel pump repair kit - repair
- intake manifold gaskets - maintenance
- PCV valve - repair
- engine air filters - repair
- spark plugs and grommets - maintenance
- valve cover gaskets - repair
- differential fluid (front and read) - maintenance (a must)
- front upper control arm bushings - repair
- cleaned MAFs and throttle body - maintenance
Old Oct 2, 2020 | 08:39 AM
ewil007's Avatar
ewil007
Ran the VIN on the car I'm looking at and it appers the control arms were recently replaced, which seems to be a common issue. Do you know if there was a redesign on the control arms to prevent premature failure or is it a every 100K mile issue that has to be addressed?
Old Oct 2, 2020 | 08:40 AM
Anfanger's Avatar
Anfanger
I don't believe so, the issue was resolved in 2013+ production years.
Old Oct 3, 2020 | 11:14 AM
R Z's Avatar
R Z
If the control arms were replaced, and the rest of the service history looks good, then I'd go for it. Brake actuators have been known to go bad, but I never had that issue in my 08. All cars need continued service so unless you're handy, find a good local mechanic and you should be fine. Good luck.
Old Oct 3, 2020 | 11:35 AM
DJWLDW's Avatar
DJWLDW
Here is a list of repairs on my 2010 LS460L: None
I just turned 85,000 on it. It came off a 3 year lease with 19,000 on it and I have not spent a dime on it other than routine maintenance. Brake pads/rotors, oil &filter, tires
Dennis
Crowncouri
Oct 5, 2020 12:12 PM
Mitleider
Mar 3, 2020 10:50 AM
DJWLDW
Jul 13, 2014 07:03 PM
LexFather
Oct 2, 2010 11:03 PM
