Ls460 sway issue
Old Sep 16, 2020 | 11:59 AM
Jvfls460's Avatar
Jvfls460
10th Gear
Default Ls460 sway issue
I can be driving normal then if I hit a rut or bump car acts funny like sways in rear maybe front too feels dangerous any ideas .. otherwise drives normal at highway speeds etc would vsc an your traction Control do this both lights are in plus VGRS but no codes
Old Sep 16, 2020 | 12:24 PM
jdanielca's Avatar
jdanielca
could be anything air suspension or stock we can speculate all day have someone take a look, what’s the other option? It could be strut mounts or the strut mount part delaminates from the strut for air suspension, the strut itself could be an issue, the tie rod ends inner and outer, sway bar bushings and links I think affects turns and handing a, Could also be the various bushings on the front end or Back end.., was that helpful ? No this this sort of situation where it’s suspension related...
it’s hard to say but having said that when you say sways I think you mean where it goes on a weird small bump where the bump is smaller or same size as whelk you get latertal movement side to side movement in that case check strut mount or struts and the bushings that connect to the strut directly
Old Sep 16, 2020 | 01:28 PM
Jvfls460's Avatar
Jvfls460
10th Gear
Ever drive a suv with big rims an hit a rut? Like that almost like it’s losing control it’s crazy or it’s just over exaggerated cause 460 is so big taking to the shop tomorrow
Old Sep 16, 2020 | 04:15 PM
jdanielca's Avatar
jdanielca
really never had it the way you said it, but for fun let’s take a bet I say some essentially bushing connected to steering is totally ****ed or the tie rod ends OR the strut mount, do post back so we can all learn thanks
Old Sep 16, 2020 | 04:18 PM
Jvfls460's Avatar
Jvfls460
10th Gear
I hope it’s something simple I’m thinking rear struts or rear arms
Old Sep 16, 2020 | 04:23 PM
jdanielca's Avatar
jdanielca
do you have air?
Old Sep 16, 2020 | 04:38 PM
Jvfls460's Avatar
Jvfls460
10th Gear
I just replaced fronts with regular struts from air but left air in rear for the time being but I have new struts to replace them .. I had a bad strut up front an it did it when I got it like that 2 weeks ago
Old Sep 16, 2020 | 05:40 PM
jdanielca's Avatar
jdanielca
Cool let’s see what they say take some photos if you can I’m curious to see. Btw I swapped all to oem non air I am freaking loving the tightness of everything it’s amazing
MrDOS
Sep 3, 2024 01:59 PM
Sportznuts
Dec 25, 2020 09:49 PM
amit1947
Jan 6, 2014 10:51 PM
