Alternator wire diagram?
Alternator socket loom
Can anyone help me out with what wire does what? My plug broke and my new plug just arrived and I have zero clue the orientation, any help would be appreciated.
One of green wires is connected to a 10A alternator fuse. You will have continuity from the fuse box when to connected to the fuse to one of green the alternator wires. Also, the same wire will be powered when ignition is on. Do not shorten wires.
One of green wires is connected to E/G RM-IG1-1 located in the right fuse box of the engine compartment. You should be able to probe for continuity from the fuse box all the way to the alternator plug. That green wire is #2.
Thanks this work with Toyota aftermarket plug from Amazon next day if anyone has to replace plug
https://a.co/d/44rU6iE
LS460 isn't listed but after going to pic n pull to confirm off a same year Camry it worked. .
After consulting with a couple mechanic clients I spliced wires by soldering them then using heat shrink tubing as well as high temp electrical tape.
Where did you get your after market plug from? My power steering is failing now and I read on forums it's a problem of not enough power to steering pump. I wonder if the after market plug on alternator was no good.
Thanks
Thanks
