I was installing a 3ch dashcam yesterday and ran the power wire to the console and the rear cam wire down the pass side and while I had it apart realized working on that side for servo problems wouldn't be very hard and it doesn't take long to get to the point where it's all wide open. It's always easier when you give yourself some room to work, I wasn't working on the servos but I did take it down to where I could see some of them.
I probably should have looked a little closer at what I would need to remove to get to it when I had it open but once I figured out it was the servo and not having one I moved on to my temporary tape fix. It looked impossible to remove the servo from what I had removed up to that point. Very little room to approach it from the left side. I think I saw the first screw but there will be one more on the back side of it.
