High Beam Bulb Replacement
Old Mar 28, 2020 | 07:23 PM
CRSO's Avatar
CRSO
Default High Beam Bulb Replacement
Hello all.
I assume to change the high beam bulb that I'll have to take apart the washer nozzle and a few other items to get to the compartment? I've searched around and can't find anything...
Old Mar 29, 2020 | 01:32 PM
mdpresco's Avatar
mdpresco
Lexus hasn’t made very many things easy. Headlights included. I replaced my low beams by removing front tires and the fender well liners.
I may be mistaken but you may be able to access the high beam through the fender well liner, reaching through the hole and past the low beam light. I would not take apart the washer nozzle and go in from the front.
If not, then I would remove panels panels under the car and maybe the bumper to reach it from the bottom. Maybe someone that has replaced their high beams with LEDs will chime in.
Old Mar 29, 2020 | 02:37 PM
CRSO's Avatar
CRSO
Thank you for responding and I ended up getting them replaced...
Remove both plastic covers... On the drivers side, remove the top part of the washer fill tube (one 10mm bolt) and for the passenger side, push aside the fuse box after removing the two 10mm bolts.
Old Mar 31, 2020 | 05:03 AM
johnnyg66's Avatar
johnnyg66
Yep, Thats how you do it. There is a DIY on changing the DRL bulbs and it shows you how since its the same bulb on early models.
Old Mar 31, 2020 | 05:21 AM
CRSO's Avatar
CRSO
that’s for low beams; I didn’t see anything for high beams?
Old Mar 31, 2020 | 02:33 PM
johnnyg66's Avatar
johnnyg66
Did you see this post?
​​​​​​https://www.clublexus.com/forums/ls-...n-drl-diy.html
It shows about what you just did.
Old Mar 31, 2020 | 03:23 PM
CRSO's Avatar
CRSO
Ugh, no. Thank you
lostang
Apr 17, 2010 09:19 PM
mepezzella
Feb 22, 2010 02:03 PM
jsquared
Lighting
Jan 13, 2007 06:25 PM
