A money pit
Or pony up and buy a new one and care for it from the beginning properly.
Just because you weren’t happy with yours doesn’t mean the people that are happy with theirs are wrong. Just move along and buy something else.
If consumers allow the company will do or not do.
You guys have lost the “pursuit of perfection” (Lexus slogan) if you think the 4th gen 4 LS is a great car, it leaves much to be desired from a luxury sedan and again I will say the used market value for these cars speaks to that as many people just want out of THE MONEY PIT the market is flooded with used LS460s and they are all someone else’s problem that they are getting rid of end of story.
My LS is the best car I’ve ever had. If it becomes problematic later in its life, I will trade it in on something new, no big deal.
SW17LS , 08-20-19 07:30 PM
So I've developed this symptom while braking, its almost like a "crunch" type feeling, started VERY sporadically but its gotten worse and now I can feel it sometimes when even pumping the brakes while I'm stopped. Going to have Lexus look at it obviously, but does that sound like the sort of symptom those of you who have had actuator failures have seen?
Car has 29,500 miles on i
there is no reason under any circumstances a brake actuator should fail with that low of mileage period. And your LS is a 2017 right? Mine was an 09 that failed, that gives Lexus 8 years to correct the problem which they did not. They put a bandaid on it to buy them more time with their warranty enhancement program.
Every car I’ve ever had has had some sort of warranty repair in its life, including all of my older Lexus vehicles.
None of those issues would preclude me from buying one because they’re well documented and the vehicles are old and won’t be perfect.
Another part of owning a car like this is shops and things not really understanding how to work on them and trying to overcharge you, especially a 600.
I did my research and neither of the GXs I own have that color, nore the kdss system. The GX I recently traded the LS for is now at 120k miles and runs like a top with guess what no problems, no shimmies, nothing.
The 06 I have owned for over three years has 184k miles and runs like a top, no shimmies, no shakes, nothing. Yes I have replaced the radiator, both cv boots, & rear air suspension bags all rubber and plastic parts that most definitely will fail given that age and miles, those were very easy repairs as well.
Those are okay to me, I am not okay with something like a brake actuator that fails to the tune of min $700 up to $3000 and has been faulty for about 10 years on the same car. That shows me Lexus is losing their pursuit of perfection.
Well, no melting interior panels if you live somewhere that isn’t a hot climate.
That’s what’s called a “double standard”
Perfection doesn’t exist, that’s why it’s the Relentless PURSUIT of Perfection.
Ive said it before, I’ll say it again. The LS460 is a reliable, fantastic automobile. Parts are very expensive. That’s the problem. And most of these cars are now 10 plus years old. That’s the problem. Not your “control arms”, that a high school automotive student can replace in under an hour...not your melting arm rest, that an upholstery shop can repair for $150 bucks. The problem is YOU. You should have bought that 8 year old Toyota Camry...and then complained about the $4,000 repair bill it needed for struts, alignment, check engine light and valve cover gaskets. Then you’d be happy buzzin down the highway in a tin can.
No matter how the car has been cared for or driven from new these parts should not fail at the rate they do.
