Upper Dash Rattle!
Old Sep 3, 2019 | 01:00 PM
Zoraone's Avatar
Zoraone
Default Upper Dash Rattle!
So I’m about to give up. For the life of me i can’t find this rattle.
At first I thought it was in the upper area around the moonroof.
then I pulled the NAV and radio.
I then pulled the glove box.
Finally I popped out the upper tweeter/speaker.
The rattle won’t go away.
It sounds like squeaking or tapping of something hitting a hard surface. Like taking your finger nails and tapping a glass window.
I honestly don’t care if i can’t fix it. I just want to know WTH it is!!!!
Old Sep 3, 2019 | 03:20 PM
tx170754's Avatar
tx170754
It may be the dash, and if it is, it is inside, try to put some felt and see if it is getting better, it did the trick in may case but I used a lot on almost all the area between the glass and the dash, you have to push it in as much as you can.
Old Sep 3, 2019 | 06:41 PM
Zoraone's Avatar
Zoraone
Thanks. Makes sense.
Did you just push push as much down as you could?
use anything special?
Old Sep 3, 2019 | 07:32 PM
DerrickM's Avatar
DerrickM
Ugh, rattles drive me nuts. Did you have somebody else drive so you could get your ear up close to areas you suspected?
Old Sep 4, 2019 | 04:43 AM
tx170754's Avatar
tx170754
I have used felt you can buy at Hobby Lobby pushed as much as you can inside, you may need to put more than one layer.
johnnieliu
Apr 22, 2025 12:25 PM
ls460love
Mar 17, 2009 07:10 PM
ESDragon
Dec 17, 2007 10:31 AM
MR.FG
May 5, 2007 03:41 PM
Ramirez
May 5, 2004 09:28 AM
