Replacing Mass Airflow Sensors?
The Dealer wants $1043 to replace them?
How many are on the 460?
I've replaced them on my Porsche and it's a relatively easy job.
How difficult on our LS?
Finally, best place and price to buy replacements?
Thanks for the guidance!
There are two MAF sensors, they're easy to get to. $190ish each from an online discount dealership
https://parts.longolexus.com/oem-par...sor-2220438020
What symptoms are your car exhibiting that lead you to believe that the sensors have both failed and need to be replaced? If they are merely dirty, you can try spraying MAF cleaner on them and see if your car shows improvement.
yup they as sooooo easy just remove the plastics u will see what u need to unbolt.... if i can figure it out, anyone can.. but yeah clean with that CRC or whtever brand it was MAF cleaner n see how that goes.
Getting the ! Malfunction indicator lamp and the System Warning light with no sound.
Dealer ran diagnostics that pointed to the MAFs.
Was also getting PCS and VSC warnings but those are suspension systems so can't see how they can be related to MAF failure.
Thanks.
Getting error messages:
Thanks.
Thanks.
My Lexus dealer estimated $550 for replacing MAF sensors, when my LS460 was 4 year old with 35k miles. I called Lexus USA and they paid for the parts and I only paid ~$120 for the rest.
It sometimes runs pretty rough right after you spray them but it should smooth out. How many miles are on your LS, what year?
Turns out I knocked the wiring harness to the throttle body loose when I replaced the MAFs.
Plugged it back in, disconnected the negative connection on the main battery for 5 minutes to reset the brains. Reconnected the battery cable, started it up.
Car went through the diagnostic reboot sequence then smoothed out.
Now running better than ever with noticeable improvement in fuel economy.
MAFs are a maintenance item. If you have over 150K miles on your LS460 consider replacing them. The benefits are significant for not much money.
sherlock
Apr 8, 2008 04:11 PM
