Replacement side mirror glass
Old Jul 15, 2019 | 11:20 AM
jdanielca's Avatar
jdanielca
Default Replacement side mirror glass
Hi
Anyone found replacement side mirror glass that is auto dimming and heated and that we can just clip back in? Ive looked around and cant really come up with much for the 2007.
Old Jul 15, 2019 | 11:51 AM
jdanielca's Avatar
jdanielca
Originally Posted by FunFact
OEM, OEM, or OEM. Otherwise, you get to compromise with no dimming.
by oem you mean factory part? nah I am not going to pay however much they want... for something that is going to crack so easily. so maybe i shall go non oem. but i still cannot really find options for that
Old Jul 15, 2019 | 12:25 PM
Kansas's Avatar
Kansas
OEM part numbers for exterior mirror glass appear to be the following for a 2007 LS460 and are typically discounted to less than $300. I've never found Toyota/Lexus exterior mirror glass to be particularly fragile but no mirror glass can withstand an impact such as from vandalism.
RH: 87931-50550
LH: 87961-50510
Old Jul 16, 2019 | 12:49 PM
DavidinCT's Avatar
DavidinCT
RH: 87931-50550
LH: 87961-50510
Agreed, Owned LS models now for over 20 years and family members have had Lexus and Toyota models.... Never head of a side mirror glass broken...and this is the first thread I remember seeing..
For the OP... Check this site.. sometimes they are insanely cheep on OEM parts and I ordered an item from them, I had it in 3 days to the US from JAPAN, and that was standard, not express shipping...
https://jp-carparts.com/
Old Jul 16, 2019 | 02:17 PM
ALK's Avatar
ALK
The problem is that the website is using the Japanese parts catalog. So if you want the side mirror housing with glass, you would get it with the Japanese spec glass, which is inverse from right to left for the glass part .
Old Jul 17, 2019 | 05:50 AM
DavidinCT's Avatar
DavidinCT
On a lot of stuff, your right but, a part number is a part number. They do not use the same part number for a different spec part in another country.
With a little homework, you can get a good deal directly from japan and fast shipping... It's worth a look..
Old Jul 17, 2019 | 06:46 AM
Kansas's Avatar
Kansas
Unfortunately, inputting the part numbers on https://jp-carparts.com for the North Amercan LS460 exterior mirror glass doesn't get a hit but inputting the part numbers for the Japan market LS460 exterior mirror glass does.
Old Jul 17, 2019 | 07:09 AM
ALK's Avatar
ALK
That's because the site uses Japanese part catalog.
Old Jul 17, 2019 | 03:31 PM
jdanielca's Avatar
jdanielca
thanks for the info guys will check it out
TLRD
Apr 12, 2020 11:53 AM
lexusdog
Nov 29, 2016 04:02 PM
antmck33
Nov 26, 2013 08:57 AM
Bumbobee
Feb 25, 2009 09:21 AM
stevies30
Oct 12, 2005 08:26 PM
