2011 LS460 Collision Warning Beeper
Old Mar 22, 2019 | 02:40 PM
jud149's Avatar
jud149
Default 2011 LS460 Collision Warning Beeper
All of a sudden the beeper is no longer beeping. Is there a on/off switch for this? Can't seem to find anything on it even in the manual.
Old Mar 22, 2019 | 02:56 PM
Kansas's Avatar
Kansas
There is an on/off switch for the Pre-Collision System under the dash on the right side per page 298 of the 2011 LS460 owners manual which you can view at https://drivers.lexus.com/t3Portal/d...f/OM50B80U.pdf
It's the left-most of the three switches that are in a row. You wouldn't be the first to have inadvertently turned PCS off.
Old Mar 23, 2019 | 10:42 AM
jud149's Avatar
jud149
Thanks. Actually, I don't think my LS has that option involving the brakes as there are no switches on the right side of the lower dash. The manual does say "if equipped" with this feature. However, on the left side of the lower dash just above a felt lined pop out tray (not sure what it's called) and trunk lid release is a switch which turns on and off the collision beeper. Apparently I somehow switched if off but all is well again. Again, thanks for your help.
Old Mar 23, 2019 | 06:46 PM
DerrickM's Avatar
DerrickM
Off Topic, but is your avatar the character from Sling Blade?! I loved that movie!
Old Mar 25, 2019 | 02:41 PM
Kansas's Avatar
Kansas
Uh huh.
ReploidX
Sep 30, 2025 02:54 PM
Eagleguy
Nov 17, 2022 10:07 AM
nikolay
Mar 23, 2018 12:42 PM
freedom88
Aug 29, 2011 09:37 AM
