ABS or speed sensor problem front passenger side, some help needed
so guys I’ve posted another thread about my AFS issues.
Using a better code reader the problem has been narrowed down to the front passenger sensor. When running you can see that is not reading the speed from that side.
So now the problem is on lexuspartsnow.com
there is like a few part numbers. Also I cannot seem to locate the part for the sensor itself. I’ll try and show you what I mean.
also the sensor could be part of the hub assembly but I am not sure, and for different production dates there are different part numbers. Should I be following the parts for my production date or should I get the part for the later production dates?
Also can someone provide sone information about this sensor? Is it part of the hub assembly? Or is there a part number for the sensor? I cannot seem to find it.
So I just replaced my hubs in December, 2018. That location you circled is the ABS sensor. There is a speed sensor, which is a PTIA to get lined up when you do the Rear Hubs, but the front was a piece of cake. It was so easy to replace the front that I would not invest a lot of money in them. I went with WSJ and they have been great, and were significantly cheaper on RockAuto.
good to know, it came with the hub as one set right? Isn’t available separately ?
