Remote start.
Old Jan 29, 2019 | 09:52 AM
Originally Posted by Steve300h
I wonder if it's to make sure you have the key before you drive off. I also wonder if you remote start the car while sitting in it and drive off will it shut the car off 10min down the road?
Other companies require the start button to be pressed again once in the vehicle to fully start it and allow it to be driven away. Much better solution.
Old Jan 29, 2019 | 12:13 PM
mcomer's Avatar
mcomer
Apparently the tech behind the door open/RS shut off involves which systems are initialized.
When the key is present inside the car during start up all systems boot up. When the key
is outside the car the engine and HVAC systems engage but not the Nav or Bluetooth portions.
Consider the result if you were within Bluetooth range (30") when the car was running. Your
phone would connect and you would have to quick get to the phones Setup Menu to hear
and speak to your caller.
Old Jan 29, 2019 | 01:15 PM
tboo72's Avatar
tboo72
Originally Posted by mcomer
The key fob cadence is the same for the current Lexus Enform Remote LER that is free for 12 months and
the Lexus Remote Engine Start RES that cost $500. The difference is that when the LER trial period ends
the fob stops working while the installed RES module keeps working.
Press the fob "lock" button three (3) times quickly and hold the third press until you see the outside lights flash.
Press/release/press/release/press/hold There are then three (3) ways to shut it down: 1) wait 10 minutes, if
you get distracted it will not run endlessly, 2) Press and hold the fob "lock" button to shut it off before 10 minutes.
3) Open any door, shuts off so you do not asphyxiate your family while loading up.
So my FOB starts the car cause I subscribe to Lexus Enform. If I stop the subscription, my FOB will no longer work to start the car?
Old Jan 29, 2019 | 03:31 PM
Steve300h's Avatar
Steve300h
I guess I'll have to try it and see what happens.
Old Jan 29, 2019 | 04:39 PM
Thats correct
Old Jan 30, 2019 | 03:12 AM
tboo72's Avatar
tboo72
Thats correct
Ah ok, then maybe the previous owner didnt install remote start. I subscribe to Lexus Enform. Until now, I didnt realize that also unlocks FOB starting.
Old Jan 30, 2019 | 12:51 PM
jimrd's Avatar
jimrd
.... I subscribe to Lexus Enform. Until now, I didnt realize that also unlocks FOB starting.
I subscribe to Lexus Enform as well but FOB remote starting does not work on my'15 (remote start via app works fine)..I thought you had to install an optional RES module to gt FOB remote starting?? Am I missing something?
Old Jan 30, 2019 | 03:26 PM
mcomer's Avatar
mcomer
jimrd, the fob button press is a bit finicky. You must press the lock button quite quickly and hold the third press until
the cars various marker lights begin to flash on their own. Usual reasons it fails are: not quickly enough and
not holding until the lights flash. The range is published as 80' but I am sure you are learning this function standing
near the car, right? Once you get it you can begin experimenting with discovering the range limitations.
Old Jan 30, 2019 | 03:35 PM
Steve300h's Avatar
Steve300h
Originally Posted by comotiger
I learned that the third press does not have to be long or held until the lights flash. I just press three times less than a second apart, and the car starts. I discovered this in a mall parking lot when I pushed the lock key one too many times, and the car started!
Not for my 2019 ES. I tried it today. It has to be short-short-long or no go.
On the plus side, the remote app was able to reach the car two levels down in a parking garage where my cell phone get's zero bars so that's impressive.
Old Jan 30, 2019 | 08:43 PM
jimrd's Avatar
jimrd
Well I'll be a monkey's uncle! Speed was the key! Not sure if this is will serve me better than the app but it's good to know! Thanks mcomer!
Old Feb 1, 2019 | 07:48 AM
mcomer's Avatar
mcomer
Dear Uncle Monkey, glad that works for you now. The fob start is short range <80' and takes a short time to start the car < 5 seconds.
The phone app start (LER and RES+, with subscription) is longer range, anywhere with cell coverage, and longer time > 20 seconds.
Old Jul 30, 2022 | 07:13 PM
KHODGES45's Avatar
KHODGES45
3rd Gear
Default Remote start
Originally Posted by jimrd
No remote start capability via my '15 FOB...I use the Lexus Enform Remote app...
2015 Lexus Ls 460 I juts got it today but it wont remote start am I doing something wrong
Old Jul 31, 2022 | 06:22 AM
swfla's Avatar
swfla
Didn't like the responses you got on your other exact same post? All the answers you need are here and on that other post.
Rick2
Dec 17, 2017 05:01 PM
twister
19
Jul 6, 2007 03:36 PM
FrankyJ
Apr 24, 2006 07:26 PM
