A/c concern
Old Jul 17, 2018 | 09:53 AM
H818R's Avatar
H818R
Default A/c concern
I have a 2008 LS460L. My automatic climate control use to come on automatically, now there is a delay. I now have to wait 2-3 minutes before I can turn it on and adjust the temperature.
The settings on the fan move from low to high, but it is only after waiting 2-3 minutes.
Can someone tell me if I am about to experience an issue with my compressor?
Old Jul 17, 2018 | 10:23 AM
Htony's Avatar
Htony
Do you have cabin air filter in good shape?
Old Jul 17, 2018 | 12:23 PM
H818R's Avatar
H818R
Default A/c concerns
WOW! Now that you mention it. I asked the dealer where my car is serviced to change the filter. He swore that they did. I have to take it out and check for myself.
Thank you.
Old Jul 17, 2018 | 12:56 PM
213374U's Avatar
213374U
Make sure the filter is fully seated and give it another go. Also, if you remove the door to access the filter and the little "accordian-style" door is closed, DO NOT force it open. Use the recirculate button to open it. If you press the recirc button and the door does not move, you'll need to pull the glovebox and reconnect the mechanism which moves it.
99% sure the above will solve your issue
Old Jul 24, 2018 | 07:49 PM
mikelaca's Avatar
mikelaca
I think it's the Air Mix Motor assuming the filter isn't it.
Old Jul 25, 2018 | 06:28 AM
H818R's Avatar
H818R
Angry A/c concerns
Thanks for all of your support.
Here is what I found. I checked the filter (to see if they changed it) and found that the entire apparatus was turned upside down. The technician did not look at the arrow and simply jammed the filter holder in place upside down. I only experienced the problem after allowing the (Toyota) service department to replace the filter.
Old Jul 25, 2018 | 11:30 AM
213374U's Avatar
213374U
Yep, that'll do it. Straighten it out, ensure that the recirc door functions when you push the button, and the error should go away.
USCRugby
Jun 16, 2023 08:22 AM
JeeKay
Jan 23, 2019 10:59 AM
Luis151
LX - 3rd Gen (2008-2021)
Aug 30, 2014 02:31 PM
WillRockwe
IS F (2008-2014)
Jul 2, 2013 03:33 AM
The1Ghost
May 30, 2011 09:38 AM
