Plz help me
Old Feb 1, 2018 | 11:08 PM
lex460l's Avatar
lex460l
Default Plz help me
i have a couple things that i don't understand on my 2010 ls460l awd hopefully you guys can steer me in a better direction
#1 is i have a humming noise that specifically comes on at 40mph, i notice it up until about 60 mph but i don't know if it drowns out because of tire noise or it disappears.
#2 i got all my rims fixed and even replaced my tires and i still have wobble that i start to feel between 50 and 60 mph, don't know what to do next
#3 my rotors always warp in literally no time, maybe under a thousand miles, and it always seems to be the right front, any ideas?
plz just give me whatever feedback you can I'm all out of ideas
Old Feb 2, 2018 | 04:30 AM
mckellyb's Avatar
mckellyb
We're going to need some more details like, how many miles on this machine, are the wheels OEM, same thing with brakes.
Preliminary assessment, however, breaks down like this:
1. Wheel bearing. See if, while it's humming, turning right or left (like on a freeway cloverleaf exit, or even changing lanes, in some cases), going either way changes the volume. Make note of which directions do what.
2. When you say "fixed", what-all was fixed? Curb rash or rim dents? Did you have it aligned, afterward?
3. If the brakes are stock, yep, that's what they do. We've had people here with brakes warped brand new, just off the lot. IIRC, the car had less than 50 miles on it.
Old Feb 2, 2018 | 09:37 AM
yyymmm31's Avatar
yyymmm31
It sounds that one of the front tires or both front tires is/are out of balance. The typical sign of unbalanced tires is that the wheels feel warped (shaking/vibrating) at certain speed range (in your case, between 40mph-60mph).
Old Feb 8, 2018 | 03:53 PM
yyymmm31's Avatar
yyymmm31
Did you solve the problem? If so, would you please share with us what was the problem and how you solved it?
Thank you.
Old Feb 8, 2018 | 04:21 PM
RA111724's Avatar
RA111724
If only one rotor is warping, maybe you have a caliper hanging up a little causing the rotor to heat up. This happened to my neighbor. He’s not too mechanically inclined so he always asked me when he has issues and he’ll give me a hand with the repairs over a few beers. He had a vibration at higher speeds and I found his right passenger caliper was hanging up. I replaced the caliper and all is well. I’m not telling you to go change a caliper. It’s just something you may check?
Good Luck
I8ABMR
Aug 21, 2022 03:58 PM
BLKSHP97
Dec 7, 2015 04:05 PM
dagloman
Aug 19, 2014 05:27 PM
Wojtasiak
Apr 9, 2014 02:20 PM
