What PSI Are You Guys Running on Your LS
#47
I noticed your LS is for sale *****, what prompted that? Didn't you just get it?
#48
Theres a few reasons for that , the main one being that the car is almost too good to be a work vehicle.....I do contract work and the common sense side of my brain is telling me that maybe an suv or truck would better suit my needs.....im racking up a ton of miles in the short time ive owned it.
But the flip side is I do a lot of highway driving and that's where the 460 shines, and I spend so much time driving and on the road that its important to have some luxury and a little style doesn't hurt either, so its a tough call.
The other thing is that after owning a supercharged z06 (which I recently sold) , I realize my taste in cars has changed. I really miss the loud engine, the shifting gears, the power and the fun factor, so I'm thinking of getting into another one, maybe a newer model or maybe even a gen 3 srt viper or supercharged dodge challenger.
its a tough call, the 460 was my dream car for years , and before that the 430, before that the 400 ... ive always loved these cars and that's what makes it a tough call
#49
Now that I would pay to see!
#52
Regarding nitrogen filling, it states "Some customers may complain about vehicle vibration due to incorrect tire balance following a nitrogen refill. It has been found that nitrogen replacement may cause tire out-of-balance conditions if the tire is deflated and refilled with weight on the tire. When the original air in a tire is evacuated during the replacement procedure, the internal pressure against the tire carcass is reduced. If the vehicle is on-the-ground during this procedure, the low tire inflation pressures may cause the tire sidewall to compress. When performing nitrogen replacement procedure with the tire/wheel on the vehicle, ensure the vehicle is lifted on a rack or jack stands. This prevents the weight of the vehicle from compressing the tire sidewall when tire pressure is reduced. Alternatively, the nitrogen replacement procedure may also be performed with the wheel/tire removed from the vehicle and suspended off-the-ground; for example, on a wheel/tire balancer machine."
#53
While I was getting an oil change and rotation yesterday, I had the dealer lower the PSI to 35 from 40 and the difference in ride quality is honestly striking. While I know mileage well might be affected due to running lower pressure and perhaps tire wear my be negatively affected, but I must say from the short duration since I got the car back, the juice seems well worth the squeeze.
So my question to my fellow 4th gen owners is what PSI are you folks running?
33psi - Helium fill - lighter car = better mileage.
audphile1
Wheels, Tires & Brakes Forum
10-08-04 08:25 AM
