Using a Techstream to lower your air-ride height
Old Mar 27, 2017 | 06:50 PM
  #31
teedub21's Avatar
teedub21
Originally Posted by comotiger
Teedub, I think Lynzoid does have a point. He has a unique way of expressing it, but there could be something to what he is saying, especially the difference between using Techstream and the Datasystems controller.
unique. Very.
Here re is a picture of my freshly washed car lowered with Datasystem controller just installed last week!
Old Mar 27, 2017 | 07:00 PM
  #32
comotiger's Avatar
comotiger
Congrats, that looks great, Teedub!! Didn't you buy a used controller on EBay? How much did it cost altogether, controller plus installation? The great thing about the DS is you have 10 different height settings, correct? What's the setting in this photo?
Old Mar 27, 2017 | 07:15 PM
  #33
teedub21's Avatar
teedub21
I picked up the controller on eBay for $500 shipped. That included the wiring harness. I installed it myself using directions I found on this forum. Took maybe 45 minutes to install.
In these photos the controller is set at level 3 front and rear.
Old Mar 28, 2017 | 09:44 AM
  #34
mckellyb's Avatar
mckellyb
Lynzoid...WAT?!
Try more actual words and some punctuation, wouldja?
Teenagers? Really? I'd be not at all surprised if I am older than you. Also, I have owned a few dozen vehicles, myself, wrenching on every single one. Two wheels, four wheels, and six wheels.
Finally, "esp system"? I know the LS460 is advanced, but I had no idea it had extra-sensory perception.
Ooooooh...ESC, probably. Lowering my car an inch has zero effect on how the car determines which tires exceeded available traction.
I'll be sure to tell you how dropping my car a little over an inch damages it over the next 300K miles.
Old Mar 28, 2017 | 10:09 AM
  #35
mckellyb's Avatar
mckellyb
Uh, oh. The transmission will fail/explode if I change the fluid and filter, too!
/facepalm
Old Mar 28, 2017 | 10:48 AM
  #36
Lynzoid's Avatar
Lynzoid
Yup, i reached this kid. And if i were you, i'd keep all that to yourself.
Old Mar 28, 2017 | 12:59 PM
  #37
213374U's Avatar
213374U
mckelly.... Looking back at your screencap, we're using the same version of TS. Have you seen a message stating it needs to update and that you can only connect XX number of times before it locks?
Old Mar 28, 2017 | 06:24 PM
  #38
213374U's Avatar
213374U
A few of the promised screencaps. One shows initial settings, one shows bottomed out after bleeding air from all four corners, and one shows the custom view I had to create because my copy of TS didn't have one preconfigured as mckelly's seems to have.
Attached Thumbnails Using a Techstream to lower your air-ride height-2_initial-settings_03242017.bmp   Using a Techstream to lower your air-ride height-3_lowered-settings.bmp   Using a Techstream to lower your air-ride height-1_custom-view.bmp
Old Mar 29, 2017 | 12:38 AM
  #39
1WILLY1's Avatar
1WILLY1
Originally Posted by mckellyb
Lynzoid...WAT?!
Don't worry about Lynzoid
always one of him in every forum
he mentions data controllers as if its any safer to use then Toyotas own techstream lol
Just to add to your thread ive been doing some of my own digging and it seems that 0.8 inches is the magic number for these techstreams, not sure why , I belive it might be the factory "wiggle room" that can be safely adjusted.
But looks like you've gone even further then that so that's pretty amazing
Old Mar 29, 2017 | 05:05 AM
  #40
comotiger's Avatar
comotiger
Originally Posted by 213374U
Any tips on how to get it to save the settings after leaving the active test? Am I supposed to be adjusting something elsewhere?
Every time I would exit active test the compressor would kick back on and raise the car back up to original height. Got it looking like this but couldn't save it
Damn, that's about where mine is and it holds. Hmmmmm.
In Height Adjust, drop each corner no more than -0.8" and see what happens. There's a theory this is the max, but I have my fronts dropped 1.1". Personally, I think the 0.8" limitation is because it refers to the Height High function.
I'll take my computer out to the parking lot, later...I keep the Techstream cable in the car...and see what it says. Regardless, I'll see if there's something special and take notes. You know how it is...you do something 20 times over the course of 90 minutes, and you forget about steps. This is even more true if you've done it over multiple days.
Hi McKelly and 213374U, It looks like you guys are trying the same thing but it is working for only one of you. While reading the Datasystems thread, I saw this post from another Techstream user to lower height (see below). You haven't referred to his method in your posts (setting reference height), so I am wondering if there is another method to lower height. If it's all the same thing, forgive my ignorance!
Originally Posted by raefkrad
I just lowered mine about an inch all around using the Toyota techstream diagnostic software. Look under setting reference height. Once done, you can then bring it back up to almost stock by hitting the height high button on your console when you feel the need.
Regards
Old Mar 29, 2017 | 07:43 AM
  #41
mckellyb's Avatar
mckellyb
I'm off work, today...odd schedule, but it's nice to have W-Th-F off...so I'll dig into it a bit. I'm going to put her up on stands to change all the transmission fluid & filter, anyway.
213374U, nope, never have seen such a message. Say, in what part of FREEDOMLAND are you?
Old Mar 29, 2017 | 11:28 AM
  #42
213374U's Avatar
213374U
Have you ever launched the software with an active internet connection? Does it try to connect to TIS update servers?
I'm down in Round Rock, just north of Austin
Old Mar 30, 2017 | 05:11 AM
  #43
mckellyb's Avatar
mckellyb
No, I am completely disconnected from the 'Net when running it.
Round Rock, gotcha. The whole corridor on I-35 between Georgetown and Austin was a shock to me when I saw it for the first time in about 15 years, a couple of years ago.
Old Mar 30, 2017 | 12:28 PM
  #44
213374U's Avatar
213374U
I see, the attached is why I ask.
And yeah, the corridor between Georgetown and Austin is insane now. 15 years makes a big difference, but we moved to the area in 87, you wanna talk about change......
Attached Thumbnails Using a Techstream to lower your air-ride height-toyota_techstream_traffic_03232017.bmp
Old Apr 1, 2017 | 03:08 PM
  #45
mckellyb's Avatar
mckellyb
I've never seen that prompt, though I may have firewalled it.
I need to correct my previous statement, as I always have a live 'Net connection, so we're the same, there. I nuked my WiFi connection the first couple of times I used it, but forgot after that.
