shudder when braking
Old Nov 7, 2016 | 11:23 AM
jfattibe's Avatar
jfattibe
Just don't go with NAPA Premiums ! I put them on a little over a year ago and now I have a weird crunching/rubbing noise under 5mph. ?? I can feel it in the petal too. I just changed the pads (Bendix Quiet Ceramic) figuring that was the problem but its still there.
Old Nov 7, 2016 | 11:26 AM
lex460l's Avatar
lex460l
Originally Posted by superdenso
maybe the tech that installed the new tires over torqued the lugs. However, either now or soon from now the Toyota rotors and pad combo develop glaze (high spots of pad material) and exhibit pulsation. I use stop tech crying drilled rotors (extreme), but a centric rotor with Akebono pads should clear things up. This topic has been discussed significantly on this site...be well
the awd models actually have bigger rotors which are basically impossible to find aftermarket, funny enough even sewell lexus gave me the smaller rotors by mistake and lexus installed them without recognizing that. I'm forced to go with lexus for rotors went with centric for ceramic pads
Old Nov 7, 2016 | 11:40 AM
I've seen the larger AWD rotors all over the place aftermarket...
Old Nov 7, 2016 | 03:12 PM
superdenso's Avatar
superdenso
The dealer can determine the cause...if they say it's the rotors/try to get them to install ur own sourced rotors for free because theirs failed during the honeymoon
Old Nov 8, 2016 | 08:23 AM
roadfrog's Avatar
roadfrog
No kidding! I just went on EBay and found at least 30-40 listings with prices starting at about 35 bucks per rotor.
Old Nov 12, 2016 | 06:38 PM
pmiller's Avatar
pmiller
Originally Posted by lex460l
im not sure honestly but i actually put on new tires right after i put of the brakes so I'm not sure exactly what they did but ill inquire about it
Unless you specifically ask them to road force your tires, chances are they didn't. The dealer told me my issue was buying tires from a low end shop. Said they probably stacked the tires and the tires were out of road. I checked into that and no they didn't. The next idea was road force. I took it to the tire shop and they road forced the tires for no cost. The tires were slightly out of tolerance. It's similar to balancing the tire. They did it on the same machine they balance the tires on. It's like and extra step beyond balancing the tires. Good luck to you!!
kphu
GX - 1st Gen (2003-2009)
26
Oct 12, 2023 05:39 PM
pmanliu
Suspension and Brakes
May 26, 2014 09:11 AM
jeff1941
Wheels, Tires & Brakes Forum
Jan 28, 2008 04:31 PM
nanotech
Jun 13, 2006 12:56 PM
theanimala
Dec 31, 2003 03:35 PM
