Unintended acceleration
Old Oct 17, 2018 | 03:59 PM
  #76
213374U's Avatar
213374U
10 posts in 8 years and 4 of them are in this thread. Alt/troll account?
Old Oct 17, 2018 | 04:41 PM
  #77
roadfrog's Avatar
roadfrog
Good point....didn't notice that until you mentioned it.
Old Oct 17, 2018 | 05:16 PM
  #78
Oh and by the way, not so impossible to press the brake and the gas at the same time. Here I am doing it:
Old Oct 20, 2018 | 04:10 AM
  #79
mckellyb's Avatar
mckellyb
Were any of you folks claiming unintended acceleration pressing on the brake with only your left foot?
If not, then you were touching the left edge of the accelerator pedal with the right side of your right shoe. You'll never feel it, and I guarantee you'll never see it.
If your right foot is involved, at all, in using the brake pedal, it's you, not the car's electronics/systems. I know you don't think it is, but you're incorrect.
Old Oct 20, 2018 | 07:16 AM
  #80
213374U's Avatar
213374U
Wait.... am I supposed to be using both feet in an automatic vehicle?!?!
Old Oct 20, 2018 | 11:00 AM
  #81
sha4000's Avatar
sha4000
Lol you should not be using your left foot to do anything in any automatic car. I'm pretty sure he knows that . At least not in the states.
Old Oct 20, 2018 | 12:02 PM
  #82
mdpresco's Avatar
mdpresco
NO FLAME INTENDED. Maybe? I didn’t know that. I guess I need to go back to driver’s education. I brake with both feet - sometimes the left and sometimes the right.
I learned to do this mostly when backing a trailer to better control the power of the vehicle. Keeping torque available by keeping my right foot on the accelerator and letting off the brake to move. My left foot now takes the place of the HOLD button on the LS.
Old Oct 21, 2018 | 02:17 PM
  #83
Tec80's Avatar
Tec80
I have different shoes that I wear at different times of year. As fall approaches, I begin wearing my Caterpillar Electric work boots, because they are warm, comfy, and durable. The sole at the toe of these boots is much wider than dress shoes. And lo and behold, I had the "brake-torque as I slow down" phenomenon happen once right after I started wearing the boots again. The accelerator is very close to the brake pedal on our cars, and as you pivot from accelerator to brake, it is very easy (if wearing large-toe boots) to catch the accelerator with the edge of the sole while braking.
Old Oct 21, 2018 | 08:36 PM
  #84
mckellyb's Avatar
mckellyb
I'm NOT suggesting people drive an automatic with two feet, I'm just saying, if you're using your right foot for braking, then you're hitting the accelerator with the edge of your shoe.
Old Oct 21, 2018 | 09:16 PM
  #85
Caflashbob's Avatar
Caflashbob
IF you are applying light pressure on the brake pedal at a stop some times the car moves a bit. Slight idle increase after so many seconds after a stop? Trans downshifting after some many seconds at a stop. Lower engine vacuum lowering the boosters power? Something is happening after maybe 10- 15 seconds at a stop. Use the hold feature. Mine moves also.
Old Oct 22, 2018 | 06:56 AM
  #86
Oliver Enterprises's Avatar
Oliver Enterprises
Former Sponsor
Caflashbob - It may be the A/C compressor kicking on (and off). When it kicks on, there is a slight increase in rpm to overcome the compressor drag. Perhaps you're feeling that. And, most A/C systems are not supposed to turn on / off like that at idle. It generally represents low A/C refrigerant. However, with our cars, putting it in ECO mode (which I do) may cause the A/C compressor to turn off (at idle, then back on so the car doesn't get to warm) in order to reduce fuel consumption. That's something I don't know … I only speculate. Mine turns on / off at idle. I can't feel it, but I can hear it due to the Exhaust Vents.
Old Oct 22, 2018 | 07:04 AM
  #87
Caflashbob's Avatar
Caflashbob
Thanks for the heads up. I think you are correct. A/c compressor cycling? Will check charge. May be original 10 year oem setup.
Old Oct 27, 2018 | 09:08 AM
  #88
mckellyb's Avatar
mckellyb
The compressor should cycle, regardless. At least, unless you just started the car and it's hot, then it'll run for a while, non-stop.
Long gone are the days when a compressor ran 100% of the time, whether more compressed refrigerant was required or not. That was just wasteful of both gasoline and compressor life.
What you have to look for is short cycling. Clicking on for a second, back off for a couple of seconds, on for a second (and it might be half a second, it's quick), and back off. If it does that, then you have a low charge.
What you feel when the A/C kicks on is the idle speed solenoid compensating for the extra load of the compressor. Normally, they're pretty smooth, but over time, yeah, they can get kinda ham fisted as they age.
Old Oct 29, 2018 | 07:48 AM
  #89
213374U's Avatar
213374U
Hmmmm, did not know this but I've noticed short cycling lately while sitting parked. I thought that maybe it was just trying to maintain the set temp so was cycling on and off, but this may be worth looking into. Intervals are around 5 seconds at times. Doesn't happen while driving that I can tell.
Old Oct 29, 2018 | 08:14 AM
  #90
jrmckinley's Avatar
jrmckinley
If you haven't already, highly recommend listening to Malcolm Gladwell's podcast on this topic. Part of his "revisionist history" series. It's really fascinating.
