A/V Upgrade for Lexus
Old Nov 12, 2016 | 04:25 PM
  #136
rehr0001's Avatar
rehr0001
Originally Posted by leonrojo18
I got everything working except CarPlay. I have the app, but how does one activate it? When I click on it, it just says manual or automatic connection
plug in your phone, then click the CarPlay app.
Old Nov 12, 2016 | 04:48 PM
  #137
leonrojo18's Avatar
leonrojo18
does not work. It just says auto/manual connection option
Old Nov 12, 2016 | 05:09 PM
  #138
rehr0001's Avatar
rehr0001
The USB you connect to has to be in one of the specific ports, think it's usb1. When it is correct, the CarPlay icon will turn green. Need iphone5 or above, too, I believe. When you plug it in, your phone will say CarPlay and there is some authorization you have to do.
Old Nov 12, 2016 | 05:45 PM
  #139
leonrojo18's Avatar
leonrojo18
DUDDEEE!! Now I see why this unit is great, CarPlay is incredible! Thanks for the help, I would buy you a steak if you were here. The problem was: a USB HUB. Disconnecting from the hub solved the issue. Hub was in USB1. I strongly suggest everyone here as well to get the rii i8? keyboard for input.
Old Nov 15, 2016 | 05:26 PM
  #140
k311in's Avatar
k311in
Finally got around to getting the unit installed. Is it me or is the system extremely slow? any setting I need to change to speed things up? the unit runs like my note 2 slow
Old Nov 16, 2016 | 08:49 AM
  #141
drcabral's Avatar
drcabral
I can't get vline (no picutre on display screen) or ivic 5d(lines through pictures per installer) to work with my nav system. I have an LS460 with Mark Levingston w/o self parking. It came with no cable connected to to the blue video display port in back. I need to know if Lexus/Toyota, has either nav software that doesn't allow the video display port to work properly or is it a hardware issue with some nav units allowing access to the video display. Thanks for your help
Old Nov 16, 2016 | 08:10 PM
  #142
k311in's Avatar
k311in
so after letting it sit a night. came back to try this morning and seems like the lag is pretty much gone. still not as fast as I would like it but it's bearable now. guess it just needs to settle down and a good reset. installed Google maps but am unable to use the mic button to enter directions or ask for a poi
Old Nov 18, 2016 | 09:47 PM
  #143
leonrojo18's Avatar
leonrojo18
Installed this a week ago and today big problems started with the video and reverse camera would not work, see YouTube video below, I looked at the unit and pressing up on the DisplayPort video cable solves this issue. Very strange, I will be calling grom.
https://youtu.be/1B_7yL73iTQ
Old Nov 19, 2016 | 10:36 AM
  #144
rehr0001's Avatar
rehr0001
I had a very similar problem with a vaistech unit I had on my LS430 - turned out to be a bad harness and once replace worked like a charm. Hope it's the same for you.
Old Nov 25, 2016 | 06:33 AM
  #145
Arvid's Avatar
Arvid
Hi, So My VLine went bad, all original navigation buttons did not work and the screen was black, The VLine looked dead, could not measure any voltage and no green LED lighting up inside the box and was yesterday sent back for a new one ..
meanwhile I have bought me a Samsung 7, what do I need to get hold of for mirroring the phone when I get a new VLine ???
Arvid
Old Nov 25, 2016 | 03:01 PM
  #146
Toshi1's Avatar
Toshi1
Have any of you got Netflix working on your vline? Don't mind much of the bugs, but really wanted Netflix to work. Ideas?
Old Nov 25, 2016 | 08:30 PM
  #147
comotiger's Avatar
comotiger
Arvid
Sorry to hear about your VLine problems. Hope the new unit solves things. VLine is not meant for mirroring your phone. Beatsonic makes products for mirroring your smartphone.
https://www.clublexus.com/forums/ls-...n-2014-ls.html
Old Nov 28, 2016 | 12:45 PM
  #148
k311in's Avatar
k311in
haven't tried Netflix but installed kodi and it works just fine
Old Nov 28, 2016 | 07:29 PM
  #149
k311in's Avatar
k311in
Been running car launcher pro and I must say the launcher is leaps and bounds over the stock launcher. Visually appealingly and loads up after restarting the car a lot faster. Only took 5 secs. Was even able to get waze to finally work . There's a trial version if anyone else wants to try it out first. It even got the mic to work while using maps. So gotta say now I am 100 percent happy and satisfied with the vline purchase
Old Nov 29, 2016 | 06:44 AM
  #150
rehr0001's Avatar
rehr0001
I'm a total android newbie (only use ios) so this may be a really stupid question. If you change your launcher, do you still have access to CarPlay? I'm not sure how the structure goes - ie - is CarPlay on the vline itself, or is it a program within a the stock launcher.
