LS460 air shock to Suncore spring conversion
Old Oct 21, 2022 | 03:49 AM
  #31
ausLX's Avatar
ausLX
Originally Posted by derreckla
if your not suppose to kill power to compressor what are supposed to do then? I am in process of doing conversion now....
Leave height sensors in place, pull fuse for air compressor.
Old Oct 21, 2022 | 06:51 AM
  #32
derreckla's Avatar
derreckla
Did anyone else have a hard time fitting in new rear shocks? Mine are about 1.5 inches longer then they need to be to slide right in. I tried to put weight on hub to make it go down so I can make it work but I am not heavy enough. I have a friend coming over later who is about 100 lbs more then me so hopefully he can help me.
Thanks
Old Oct 21, 2022 | 06:53 AM
  #33
derreckla's Avatar
derreckla
Found the solution for anyone who has same problem
Old Oct 21, 2022 | 04:35 PM
  #34
Anfanger's Avatar
Anfanger
I had no issues replacing rear struts, however, I got air suspension. If I remember correctly, I had to remove sway bar links.
gsfdream
GS F (2016-present)
32
Jan 7, 2021 09:24 PM
tnbigdawg
Oct 6, 2020 06:47 PM
fly_s2k
Nov 11, 2014 08:04 PM
20GS300
Jan 3, 2014 06:08 PM
Cronic
Jul 2, 2012 12:29 PM
