TPMS Adjustment
Old Jul 24, 2015 | 10:32 AM
DJWLDW's Avatar
DJWLDW
Default TPMS Adjustment
One of my TPMS's always shows up 1 PSI pound higher than the other 3 TPMS on the ground. I check them with the same digital gauge. They all show the same on the gauge but the left rear always shows 1 pound higher on the dash display. Is there any type of adjustment for our TPMS's
Dennis
Old Jul 24, 2015 | 01:24 PM
jmcraney's Avatar
jmcraney
Dennis,
While it is possible that one of your TPMS tire sensors is 1 PSI different, that is unlikely. Some digital gauges have only 1 PSI resolution, so if you are using that sort of gauge then that is a 1 PSI uncertainty and the car only displays 1 PSI resolution and maybe the sensors only quantify 1 PSI resolution - not sure about that - then it is easy to account for the 1 PSI difference. If you are using a digital gauge with 0.1 PSI resolution then try testing with a pressure that is 0.5 PSI higher or lower. You might have better luck convincing yourself if you use a dial type gauge with a bleeder valve to set your tires to the "same" pressure as that would remove some of the uncertainty, some of the time.
There is no calibration or adjustment in the TPMS.
While that sort of difference is irritating to people like me and you, it doesn't compromise the enhanced safety that the TPMS is designed to provide.
Old Jul 24, 2015 | 01:33 PM
DJWLDW's Avatar
DJWLDW
Thanks JM
I have several different gauges. I will try the others and see if I show an difference.
Dennis
Old Jul 24, 2015 | 01:38 PM
jmcraney's Avatar
jmcraney
Forget about the accuracy and go for the resolution. If you have a dial gauge with a bleeder valve, use that one. And make two sets of measurements that are 0.5 PSI apart - set the pressure to 33.0 PSI on all tires and then set the pressure to 33.5 PSI.
Old Jul 24, 2015 | 02:51 PM
DJWLDW's Avatar
DJWLDW
JM
I don't have a gauge with a bleeder valve. Sounds like time for a new tool!
Dennis
Old Jul 24, 2015 | 03:20 PM
jmcraney's Avatar
jmcraney
Here's one that has accuracy, resolution and a bleeder: http://moroso.com/eb/catalog/navigat...nuId=main.menu
A better solution might be a trip to the Crystal Bridges Museum to get your mind on something else.
It's so hot and dry here I can't think of anything pleasant.
Old Jul 24, 2015 | 04:32 PM
DJWLDW's Avatar
DJWLDW
Been there 5 times already. If you have never been, it is really worth the time. It's like when we were stationed in DC. Every time friends/family came to visit it was I want to go see? I could do the sites in my sleep.
Dennis
PS: not dropping $80 for 1 psi.
Old Jul 24, 2015 | 04:44 PM
jmcraney's Avatar
jmcraney
Everyone: See what going to the Crystal Bridges does for you - makes you smart, and the museum is free too.
Old Jul 24, 2015 | 05:55 PM
dlbuckls10's Avatar
dlbuckls10
1 PSI shouldn't make that big of a difference for most of us. If your tire pressure is too low or too high the sensor will give a warning. I had my tires rotated, balanced, pressure checked at the dealer and the pressure varies 1 or 2 PSI per tire after I drive my car.
Old Jul 27, 2015 | 06:56 AM
R Z's Avatar
R Z
It's so hot here in Memphis, I am melting!
As for tire pressure, unless you think you are having some sort of leak, I'd certainly leave it alone. Shortly after I got my car, the tire sensor went off. Took it to the dealership, had nitrogen installed and it's been fine ever since. Does the nitrogen make a difference? I couldn't tell you. But the sensor has not alarmed since (Of course now that I've jinxed myself, today when I get in my car . . . . . . )
Old Jul 28, 2015 | 05:28 AM
wbrian63's Avatar
wbrian63
Available on Amazon for $68, but that is still spendy for my budget...
colfax
May 22, 2018 01:09 PM
RiojaRed
Sep 25, 2017 11:54 AM
iWannaGS
May 11, 2017 07:43 PM
redcupr
Dec 10, 2013 07:08 PM
Mike_TX
Jun 15, 2008 02:46 PM
