New Guy
Old Jul 15, 2015 | 04:34 PM
  #46
jfattibe's Avatar
jfattibe
Originally Posted by Devh
Your are probably best served by researching the issue.
https://www.clublexus.com/forums/ls-...eleration.html
You should go to the Lexus drivers site and set up an account and enter your VIN number so you can search your cars service history.
http://drivers.lexus.com/lexusdrivers/my-lexus/home.do
It might be something as simple as a programming fix.
Already done.
Old Jul 15, 2015 | 11:22 PM
  #47
NickTee's Avatar
NickTee
Originally Posted by jfattibe
Thank you for your response. It is my first oil change I purchased the car in June. I've had the hesitation since. I don't know what oil the dealer had in it but it smelled like dino( don't know if synthetic smells different). I took it out today and put on 20 miles and its still there. I did read in an older forum that it could take a couple hundred miles to clear up but I don't see why ?
Conventional and synthetic oil are both that: oil. They're not two magically different things and you certainly wouldn't smell any difference unless the synthetic oil you use is loaded with detergents.
The reason that it can take several hundred miles is that build-up of gunk is not instantly cleaned out. It's like trying to wash a really filthy, moldy bathtub. It's not just cleaned off with a single spray of cleaner and some wiping. It requires time and repeated cycling.
And that's not even to say that this is your issue. The oil change and the issue may simply have a temporal relationship, rather than a causal-effect relationship.
Old Jul 16, 2015 | 07:51 AM
  #48
Devh's Avatar
Devh
Already done.
What did you find out in the history regarding oil changes.
Was the oil changed at the dealer?
If they used synthetic oil it might be in the notes as customer requested synthetic oil.
As NickTee pointed out, a synthetic oil flush takes a long time to erode deposits as much as 30k miles to fully clean the engine however it's the safest way to clean a motor that has conventional oil deposits.
The initial cleaning of synthetic oil is a little more course because of the high detergent action but as it settles down it will begin to erode varnish deposits by liquefying and holding it in suspension.
Old Jul 16, 2015 | 12:51 PM
  #49
jfattibe's Avatar
jfattibe
It does state oil changes but it doesn't say what they used. I would like too think that Lexus would use synthetic but who really knows ?? I did read all of the link concerning the hesitation and even know it seems the consensus is the oil but its really a crap shoot, reset ECU, change trans. fluid and filter, run Toyota engine flush through motor ???!!! If this doesnt clear up in a couple of months im thinking of running some Marvel Mystery oil through it for a couple weeks then changing again. Its really disappointing considering who makes these things(Toyota) and how much you pay for them.
Old Jul 16, 2015 | 01:02 PM
  #50
CRowe14's Avatar
CRowe14
It does state oil changes but it doesn't say what they used. I would like too think that Lexus would use synthetic but who really knows ?? I did read all of the link concerning the hesitation and even know it seems the consensus is the oil but its really a crap shoot, reset ECU, change trans. fluid and filter, run Toyota engine flush through motor ???!!! If tjis doesnt clear up in a couple if months im thinking of running some Marvel Mystery oil through it for a couple weeks then changing again. Its really disappointing considering who makes these things(Toyota) and how much you pay for these things.
I hope im not overstepping here, but I don't think it has as much to do with the company who engineered this engine, but more so how the car was treated and taken care of.
Please don't take this the wrong way, but I believe that you stated that you noticed the car had a hesitation issue before you decided to make the purchase. Now, granted as a few trusty members have pointed out, it could be the oil. From the sounds of it, it will have to cycle through and you're now playing the waiting game. Its the situation your in for purchasing a car with an issue, be it large or small.
With the reading I've done regarding the hesitation issue, I don't think it'll be anything that will require some grand amount of attention from a repair shop, but who really knows.
All that to say, please don't begin to slander Toyota or the vehicle, when you purchased a used car with a known hesitation issue. Its simply not justifiable, as there are a myriad of reasons as to why this issue exist.
I do hope though, that you are able to resolve your issue with the cycling through of new oil.
Old Jul 16, 2015 | 01:05 PM
  #51
swfla's Avatar
swfla
Seems a bit premature to be disappointed in the manufacturer when all you've done is DIY, bought into what you've read on this site ( it's not gospel fact ) and not gone to a qualified dealer for diagnosis/repair. You did buy a warranty. Remember, I didn't say you're wrong, just a bit premature. Just my opinion, not meant as a judgement. I just want you to be fair to yourself before becoming disappointed. Good luck.
Old Jul 16, 2015 | 01:11 PM
  #52
CRowe14's Avatar
CRowe14
OP, swfl was able to communicate what I was trying to communicate in a much more polite manner...
By no means did I mean to come across brash or disrespectful, so it is my hope that it wasn't construed in that manner.
But do give it a little time and as swfl said, you do have a warranty...
I honestly believe the car will be just fine.
Good luck Sir!
Old Jul 16, 2015 | 01:14 PM
  #53
MrMark's Avatar
MrMark
Originally Posted by CRowe14
Congratulations on the purchase good buddy!
Now, as you should know from being an astute visitor, now member of the forum, the same rules apply:
A pic of two of the exterior (interior optional) and a bit of back ground on your search and find.
Also, fellow member and forum Moderator CJITTY started this thread some time ago so that every one could familiarize themselves with one another, so feel free to place your entry there as well!
Again, congrats and yes indeed, its a great car!
CRowe.....go to Fizz Autosports in Chicago for all your LS needs.
Old Jul 16, 2015 | 01:19 PM
  #54
CRowe14's Avatar
CRowe14
Umm..HIJACK!!!!!
Jk!
Thanks Mark.
Just FYI, I have a thread active regarding my situation called "Upper control arms!"
Thanks again!
Old Jul 16, 2015 | 01:54 PM
  #55
Devh's Avatar
Devh
If you have a warranty with the car then don't do anything and just have the dealer deal with it.
I recall there were some that got a programming update which solved their problems.
Most all Lexus cars that come in for service only got conventional oil unless the customer requested synthetic oil and it's usually in the notes.
Since 2013 it might be different because Toyota is pushing synthetic oil.
There is nothing wrong with conventional oil changes for your Lexus however when switching to synthetic oil you may encounter issues but that is still speculation.
As I said before this may or may not be your issue. I would not run additives in your engine oil, the synthetic oil acts like a flush on it's own and if it's the issue one good indication is if the hesitation goes away after 1k miles.
Till then don't get overly exited about the thread linked as it's all speculation that may point you in the right direction.
Old Jul 16, 2015 | 02:08 PM
  #56
Devh's Avatar
Devh
One last thing. When you mention hesitation on acceleration do you mean down shifting hesitation ?
Does the car seem to bog down and then jerk to accelerate?
If you could describe the quality of hesitation it would help.
Old Jul 16, 2015 | 02:47 PM
  #57
jfattibe's Avatar
jfattibe
Good luck Sir!
Don't worry, I have pretty thick skin. Im not taking anything as gospel it just seems like a lot of people are having these problems with a 70k car wheather you use conventional oil or synthetic, this should not happen. I bought my Honda Civic new in 06 and had zero problems and paid 20k for it. Don't get my wrong, I love the car and I'll see what happens in the next couple of months. If nothing changes I'll utilize the warranty and bring it in. Unfortunately I didn't feel the hesitation during the test drive but yes it boggs down while trying to accelerate around 2k rpm and if I keep the pedal down it clears up around 3k rpm and it doesn't down shift. I believe it's in second gear at that point.
Old Jul 16, 2015 | 03:30 PM
  #58
Devh's Avatar
Devh
You have to keep in mind that it's not a lot of people. Every car will have some minor quirks or issues that can be rectified. Internet forums can be deceiving as to the scope of the issue because the vast majority will not have that problem, only those few that scream the loudest because it's their issue.
A Civic is a great car but if you go to a forum you will find those that have issues as well.
Also keep in mind you bought a used car with 70k on the clock. You don't know how it was maintained or driven.
Old Jul 16, 2015 | 03:37 PM
  #59
jfattibe's Avatar
jfattibe
All true, thank you.
Old Jul 16, 2015 | 07:35 PM
  #60
Devh's Avatar
Devh
Please report back within a 1000 miles if the hesitation disappears. If it does then we would like to know about it.
CJITTY
Oct 10, 2013 07:35 PM
LScowboyLS
Jul 12, 2013 06:24 PM
TexasTex
Jul 1, 2009 06:04 PM
DaveGS4
Apr 10, 2006 09:48 AM
