Car pulling to the left
Old Oct 30, 2014 | 01:06 PM
thelawnet's Avatar
thelawnet
Default Car pulling to the left
I just bought a 2006 LS460. It's pulling strongly to the left (this is a UK RHD car). I'm assuming this is just a wheel alignment/tracking thing, but just in case it's not, are there any other potential causes that I should be aware of ?
Old Oct 30, 2014 | 01:08 PM
peteybabes's Avatar
peteybabes
do you mean 2007 with an "in-service" date of 2006?
Old Oct 30, 2014 | 01:10 PM
thelawnet's Avatar
thelawnet
I guess? It's just a regular LS460 with air suspension, registered 13th December 2006.
Old Oct 30, 2014 | 01:20 PM
Doublebase's Avatar
Doublebase
I have the same problem, I might do an alignment on it, but when I purchased it they said they just did an alignment to it and it was pulling then too.
Old Oct 30, 2014 | 01:25 PM
fly_s2k's Avatar
fly_s2k
I would recommend having the alignment checked or check for brake dragging.
Old Oct 30, 2014 | 02:32 PM
sktn77a's Avatar
sktn77a
If you're in the UK, you're driving on the left. If the road has a crowned surface, the car will naturally run to the left. Try driving the car on a flat and level surface (parking lot?) and see if it still pulls. if it does, have the alignment checked.
Old Oct 30, 2014 | 04:25 PM
thelawnet's Avatar
thelawnet
it's definitely pulling to the left
Old Oct 30, 2014 | 07:02 PM
Nospinzone's Avatar
Nospinzone
It's probably an alignment issue, but I would also have your control arms checked for wear. You may also have a problem with your tires (excuse me, tyres), what brand do you have?
Old Oct 30, 2014 | 07:25 PM
thelawnet's Avatar
thelawnet
The tyres are Dunlop Sport 245/45/19, there's a note in the newly done MOT about uneven wear to one of the tyres, I guess due to the alignment.
The upper suspension arms were replaced 7,000 miles ago.
Old Oct 30, 2014 | 09:23 PM
mrgameover's Avatar
mrgameover
check the air pressure first. being about 4psi off, it was causing mine to pull.
Danny200t
NX - 1st Gen (2015-2021)
Nov 9, 2018 05:33 PM
e-man
Oct 28, 2018 08:52 AM
funcrusher
Apr 2, 2011 07:53 PM
jhp012
Jul 11, 2008 08:32 AM
mb12345
12
Apr 6, 2005 05:58 PM
