Painting LS460 calipers and new rotors
Old 09-10-14, 12:37 AM
6sick6
6sick6's Avatar
Default Painting LS460 calipers and new rotors
A couple weeks back I painted the calipers on another CL members LS460. He also got new slotted and drilled rotors we got some paint on as well.
Heres what he started with
Heres the new rotors
So because the calipers on LS460's can be a little temperamental when trying to bleed the air out of the lines, I just decided to paint them on the car.
Old 09-10-14, 12:39 AM
6sick6
6sick6's Avatar
And spraying the rotors
Finally everything back together
Thanks for checking it out everyone!
Old 09-10-14, 12:18 PM
Lextrician
Lextrician's Avatar
Do they have black rotors for the rear? Next mod fasure
Old 09-10-14, 01:59 PM
AznRacer
AznRacer's Avatar
Those oem 6 piston calipers looks good
Old 09-10-14, 03:33 PM
dlbuckls10
dlbuckls10's Avatar
Impressive.
Old 09-10-14, 03:48 PM
lbintab
lbintab's Avatar
So since the calipers had to be removed to replace the rotors why not just repaint them off the car? Then you would need to do all that masking. It's not hard to bleed the brakes after.
Old 09-11-14, 12:53 AM
6sick6
6sick6's Avatar
Im not sure actually. Either way the brake pads will rub all the black and gold off once u hit the brakes. But u can also always spray the rotors black to match the others
Old 09-11-14, 12:57 AM
6sick6
6sick6's Avatar
The calipers have to be Un bolted with 2 bolts to replace the rotors. You don't have to take off the caliper completely and remove the brake line. I know how to bleed brakes but being that my lexus tech wouldn't even take the calipers off for me cuz he knows how hard it is to bleed LS460 brakes, I figured I might as well leave em on. Plus they use a special machine to bleed the brakes on the LS460s at Lexus and they still get air in the lines.
Old 09-11-14, 01:22 AM
lbintab
lbintab's Avatar
I replaced my brakes with full bbk and didn't need a special tool to bleed the brakes. There isn't anything special about it. The tool they probably used was a pressurized bleeder. Just allows one person to bleed brakes. But yeah nothing special at all and my lines air free with a solid pedal feel.
Old 09-11-14, 07:10 AM
roadfrog
roadfrog's Avatar
Techstream IS required. You may have solid brake feel, but that doesn't mean it was done properly. There are some here who truly believe that they properly flushed/bled their systems properly by disconnecting the NEG batter cable beforehand, but IMHO it's folly. Here is a tech bulletin and the PROPER and CORRECT procedure to peruse:
http://myvenza.ru/tech/pdf/Brake_Fluid_Replacement.pdf
For less than a hundred bucks to do correctly, why half-*** something as important as the brakes?
Old 09-11-14, 09:00 PM
lbintab
lbintab's Avatar
Good to know. We've never run into issues. We've done a number of these . We got tech stream also. Maybe we'll look at that but like I said no issues with the three 460s in my crew with bbk
Old 09-20-14, 11:49 PM
FreddyG
FreddyG's Avatar
Nice job and your car is Absolutely SICK!
Beautifully done!
Emprado
09-08-21 06:01 AM
bilgen
SC400 / 300 Classifieds
14
08-09-15 09:08 AM
Prowler217
Suspension and Brakes
09-01-08 07:41 PM
Quick Reply: Painting LS460 calipers and new rotors
