Ls 460 calipers on a IS?
IS350 calipers are a better choice. The LS460 calipers use different mounting points and the rotors have a different bolt pattern. The IS350 calipers are also aluminum monoblock and use the same size rotors as the LS460 (non-sport package). If you are looking for larger rotors, check out using a 2013+ RWD GS350 F-Sport caliper/rotor as it shares the IS mounting points and bolt pattern.
Jeff
Jeff
Sorry for reviving a dead thread.
I'm trying to see if I could put rear LS460 calipers on my GS460, the part# is the exact same for the rear knuckle on the GS460 and the IS250, and you're the only person I've found who says they've done this....
What did you do to make them fit? do they bolt-on or did you have to make an adapter? and do you have any pictures?
cssnms
GX - 1st Gen (2003-2009)
Oct 11, 2018 07:44 AM
scunyon
Dec 8, 2015 07:52 AM
LexLuger06
Sep 17, 2012 05:12 PM
