Yellow Fogs
Old Oct 14, 2013 | 07:19 PM
Haole702's Avatar
Haole702
Default Yellow Fogs
I'm interested in swapping out my fogs for yellows.....
Has anyone done this mod lately or at all?
Is is a simple DIY?
What bulbs ?PIAA?
Pics?
Old Oct 15, 2013 | 02:18 AM
1Putt's Avatar
1Putt
I used PIAA plasma yellow bulbs, they're 2500k or 3000k color I believe. There's a few diff yellow bulbs they have.
Yes, DIY by removing the wheel liner or partially removing/pull back to access the fog light. You can remove the wheel for more room to work with.
Old Oct 15, 2013 | 09:24 AM
CJITTY's Avatar
CJITTY
Check the FAQ Sticky, plenty of threads on this for background info
Old Oct 15, 2013 | 05:47 PM
Haole702's Avatar
Haole702
I went to FAQS sticky and typed in LS 460 yellow fogs .....LS yellow foglights...... yellow fogs... etc and no matches came up any thing specific a I sholud type? THX!
Old Oct 15, 2013 | 07:35 PM
lbintab's Avatar
lbintab
Go with hid 3000k fogs
Old Oct 17, 2013 | 01:56 PM
CJITTY's Avatar
CJITTY
My 3000K HID pics are in the FAQ under "Lighting" section https://www.clublexus.com/forums/ls4...d-finally.html
You can also search google for LS460 3000K or yellow fog and it immediately came up with an earlier post of mine here https://www.clublexus.com/forums/ls4...-on-ls460.html
Just get a $29 (shipped) HID kit from Ebay. You need 9006 bulb style with 3000K fogs to achieve yellow color. Install is under 30 min and it's 100% plug n play
Old Oct 18, 2013 | 06:43 AM
Tee's Avatar
Tee
The only downside to using 3000K is our fog lenses are reflectors and scatter the beam pattern, when it blends in with our 4300K low beams it make them look like halogen bulbs. I found running 5K lows w/ 3K fogs looks fantastic! However HID fogs do put out more light than standard bulbs.
https://www.clublexus.com/forums/5994574-post34.html
I have not had time to put in my new HID kit but my temporary fogs are yellow bulbs.
Old Oct 18, 2013 | 09:08 AM
ryan78's Avatar
ryan78
Tee - quick question regarding the LS fog lights, since you brought up HID. Sorry to threadjack. I currently have a GS, and had purchased the Morimoto mini h1 retrofit set from TRS for my high beam retrofit. It looks like I will be getting rid of the GS for a LS due to unforeseen issues. Is there room in the LS stock fog housing for a projector setup? The lens size is 2.5", and the projector is not much larger. I am trying not to return this, as there is a 20% restock fee. Thanks for any input.
Old Oct 18, 2013 | 02:26 PM
Tee's Avatar
Tee
Hard to say b/c I have not removed the entire housing, but it might be worth a shot. Go check an 460's fog light and see for yourself if you think its worth the mod. Here are two pics of one not in the bumper cover.
Attached Thumbnails Yellow Fogs-getimage.jpg   Yellow Fogs-large.jpg   Yellow Fogs-large_1.jpg   Yellow Fogs-kgrhqjhjboe-nwd-lecbp38-ro-yw-60_12.jpg   Yellow Fogs-kgrhqrhjboe-nw7romrbp38-tg5sg-60_12.jpg
Old Oct 18, 2013 | 03:07 PM
I8ABMR's Avatar
I8ABMR
Is there a reason you want yellow? Looks dated as hell in my opinion.
Old Oct 19, 2013 | 12:04 AM
Haole702's Avatar
Haole702
I'm on the fence....between matching ]lo-beams and fogs sets or complete contrast from original lo-beams and yellow
Old Oct 19, 2013 | 03:45 PM
LS2k's Avatar
LS2k
On a separate threa, i was wondering these
would
6000K Halogen Xenon Super White 68 SMD LED 6000K Halogen Xenon Super White 68 SMD LED
be a proper upgrade to the stock fog light bulbs and plug and play?
Old Oct 19, 2013 | 05:08 PM
CJITTY's Avatar
CJITTY
wouldVideo Link: http://www.amazon.com/Shakeproof-Halogen-Daytime-Running-Driving/dp/B00DSW28I4/ref=sr_1_2?s=automotive&ie=UTF8&qid=1381902649&sr=1-2&keywords=9006+68-SMD+LED be a proper upgrade to the stock fog light bulbs and plug and play?
Just do the HID fog mod for $30..almost no LED is as bright as HID bulb..I have 4300k in mine and use as DRLs..very bright
Sent via Club Lexus Mobile App
Old Oct 19, 2013 | 06:12 PM
LS2k's Avatar
LS2k
Got you, thanks for the clarification hid vs. Led.
Would this be the type of plug and play hid kit needed?
http://www.ebay.com/itm/9006-8000k-XENON-HID-CONVERSION-KIT-35W-LOW-BEAM-/251182879275?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ALexus%7CModel%3ALS460&hash=item3a7baa922b&vxp=mtrDo the ballasts need to be installed as well?
Old Oct 19, 2013 | 08:56 PM
CJITTY's Avatar
CJITTY
Video Link: http://www.ebay.com/itm/9006-8000k-XENON-HID-CONVERSION-KIT-35W-LOW-BEAM-/251182879275?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ALexus%7CModel%3ALS460&hash=item3a7baa922b&vxp=mtr
Yes, you need a 9006 HID kit..please look at my HID fog DIY under the lighting section of the FAQ sticky...I also recommend going no higher than 5 or 6k...4300k is oem headlights color..any higher than 5k or so, you actually lose light on the road. 3000k is yellow
