2007 LS460 Wiper Blade Insert replacement
Old Jun 6, 2013 | 03:53 PM
melnick's Avatar
melnick
Default 2007 LS460 Wiper Blade Insert replacement
I just got the rubber insert from the Lexus dealer (driver's side) but haven't been able to get the rubber blade out of the assemble. The threads that I have read describe sliding out the metal rods after grabbing with pliers but they don't seem to slide out in either direction. Any advice would be appreciated.
Old Jun 6, 2013 | 06:17 PM
williakz's Avatar
williakz
Whoa! What are you going at with pliers? No pliers, no pliers, no pliers.
Look at the wiper blade assembly after you've removed it from the car. The rubber insert can only slide out of the holder in one direction. Use both hands to "help" slide it out a little bit at a time. Then, once it's out, take out the metal rods, put them into the new rubber blade, slide it back into the holder in the reverse direction you took it out, reinstall the assembly and voila! Good luck.
Old Jun 6, 2013 | 07:01 PM
melnick's Avatar
melnick
Thanks - after a bit of fiddling I got the rubber out and then the rest was easy. I don't know why the posts that O read all suggested grabbing the metal and sliding it out..
Old Jun 7, 2013 | 07:46 AM
jlawr's Avatar
jlawr
Two refill blades: $24.03
http://www.lexpartsworld.com/scripts...&idCategory=58
Wiper Blade Refill: $24.73 for both
Left http://www.parts.com/parts/2008/LEXU...icleid=1441483
Right http://www.parts.com/parts/2008/LEXU...icleid=1441483
k2au
May 18, 2025 04:40 PM
dkang76
Feb 2, 2024 10:53 AM
98023IS250
Feb 29, 2016 01:08 PM
kidluvsole
Dec 7, 2008 07:49 PM
medialexus
Jan 26, 2005 06:33 PM
