DataSystems Air Suspension Controller info thread
Old Feb 13, 2022 | 02:29 PM
  #286
FreddyG's Avatar
FreddyG
Originally Posted by qcvc
Got it, thanks for the pictures and help! Waiting on the speed cable to come in, but you were right it is a relatively easy and quick install even if I have to go back in a second time. Took some SL pictures after install.
I agree with LWPhat! Those wheels are Smokin' (your lowered LS looks Great too)!
Can you Pleases tell me the specifics on them (brand, size,etc)?
Thanks in advance!
Old Apr 24, 2022 | 08:05 AM
  #287
Hosed's Avatar
Hosed
Originally Posted by Way
Is it safe to drive around with the data system on 5 all round. the car is AWD
as I like the look of it just on the tyres
just don’t want to damage axles
This one’s a bit lower
hey man,
What brand is that trunk spoiler?
Also the side skirts and front spoiler?
Is it all mz speed?
And the window treatments if you don't mind.
Looks great!
Old Jul 22, 2022 | 02:38 PM
  #288
TimNewman's Avatar
TimNewman
3rd Gear
Default remove/disable ASR680/681?
Hi all,
i am having issues with height and noise in the suspension and want to eliminate the ASR as the cause so want to disable it.
I disconnected it and the car threw all kinds of errors and to test it i tried hitting 'high height' and that threw an error too and the height wouldnt change.
So i figured that i cant just disconnect it to allow me to test the car without the ASR.
Is there a way to do this?
Old Jul 22, 2022 | 04:22 PM
  #289
Hosed's Avatar
Hosed
Originally Posted by TimNewman
Hi all,
Tim,
Did you plug the connectors back into the main circuit board?
Old Jul 22, 2022 | 04:29 PM
  #290
TimNewman's Avatar
TimNewman
3rd Gear
Originally Posted by Hosed
Tim,
i didnt, no. i thought in order to do that id need to re-pin them. i didnt do the conversion so not aware how it is done. if its a harness where the repinning is done at the plugs then that'd be good!!
id need to then just work out how to take all the covers off and just plug back in eh?!
Old Jul 22, 2022 | 04:54 PM
  #291
Hosed's Avatar
Hosed
[QUOTE=TimNewman;11331227]i didnt, no. i thought in order to do that id need to re-pin them. i didnt do the conversion so not aware how it is done. if its a harness where the repinning is done at the plugs then that'd be good!!
id need to then just work out how to take all the covers off and just plug back in eh?![/QUOTE
Yes, you have broken the circuit by unplugging the device. You will have to take it all apart and get behind thr glove box to put them back on the main circuit. Your errors will go away after. Once you get good at it, it will only take you 15mins or so.
There are step by step guides on this site.
Old Sep 13, 2022 | 04:04 PM
  #292
XF40FSPORT's Avatar
XF40FSPORT
Shot in the dark, but does anyone have a lightly used ASC680L & i harness for sale?
Old Sep 19, 2022 | 05:56 AM
  #293
Milon's Avatar
Milon
I don't have that specific one but I have the newer version ASR681 with H-087i harness for sale that I removed from my LS460L. Message me if interested. Thanks!
Old Dec 12, 2022 | 12:56 AM
  #294
Mig0s's Avatar
Mig0s
1st Gear
Hey guys, I have a 2009 LS460 AWD and found a local seller who has a ASR681-ii. I know the ASR681-ii is for 2013+ but would it work with my 2009?
thanks
Old Dec 19, 2022 | 12:53 PM
  #295
bfor3's Avatar
bfor3
Just in case someone is interested as well, I'm selling a brand new ASR681-II and H-087i harness together if interested please PM me.
Old Feb 2, 2023 | 10:26 AM
  #296
XF40FSPORT's Avatar
XF40FSPORT
I’m fully aware that plugging in the speed cable will disable the car from additional lowering during freeway speeds when NOT in normal mode.
I also know while in normal mode, the suspension continuously adjusts while driving, regardless of speed.
(My Indy had techstream connected & noticed the constant adjustments when he was troubleshooting my suspension prior to me having Datasystem)
My question is, IF the speed cable is plugged in & I’m not in normal mode (3 & 3, which is my preferred setting) does this disable the continuous height leveling while driving?
Im very particular about even ride height, & have noticed visual variances in ride height, particularly on the front corners.
I haven’t installed speed cable yet. Planning on tackling this w/ in a week.
Old Feb 2, 2023 | 10:20 PM
  #297
ALK's Avatar
ALK
Yes, no vehicle Height control after 50 mph when not in normal mode.
Old May 15, 2023 | 12:33 PM
  #298
XF40FSPORT's Avatar
XF40FSPORT
Default ‘13-‘17 Speed sensor
I have a asr681 2 & H-087i on my ‘13.
I recently hooked up the speed sensor, but it wasn’t working, as the height would still lower at fwy speeds.
I took everything apart today to realize that the single speed sensor wire that’s connected to the harness on female connector, doesn’t have a male connection when plugged into the car.
In other words, the female plug from harness has the speed sensor wire on bottom row, 4th pin from bottom left corner of plug. However, the male connection on the LS, doesn’t have any metal pins that would plug into the bottom row, 4 down.
I know the H-087i is the correct harness for 13+. Perhaps the harness for speed sensor is for pre ‘13 models & packaged incorrectly?
If anyone has same experience or has a speed sensor cable not in use & can send me a pic of the female plug from harness…that would make my day!
Old Jul 5, 2024 | 02:18 PM
  #299
Hosed's Avatar
Hosed
Is the chassis selection for the 2017 ls f sport the same as the others? Chassis '77' selection?
Also, is taking it apart to install the harness the same as the instructions for earlier models?
I'm attempting it this weekend.
Old Jul 6, 2024 | 02:46 PM
  #300
Hosed's Avatar
Hosed
yep, it was 77. took about 15mins, driving on all set to 4 without issues.
It was a bit different than my 2012. I didn't have to take off the dash molding above the glove box which was nice.
