Wiring help
Old May 23, 2012 | 05:25 AM
randomwalk's Avatar
randomwalk
Default Wiring help
Hey guys
Do you know which wire under the hood of the ls460 that I can tap into that will give a 12v signal only when the headlight is turned on? Thanks
Old May 23, 2012 | 07:17 AM
G-SharK's Avatar
G-SharK
Just tap it direct to on of the fuses under the hood, its located on the passenger side. Open the fuse box and look for the light fuse. I do not recommend using a light test b/c if you test the wrong wire, like ABS your ABS light might display and it will cost you to get it off.
Old May 23, 2012 | 07:33 AM
randomwalk's Avatar
randomwalk
Sorry how do you tap into a fuse? I have done with wire but not fuse
Old May 23, 2012 | 11:04 AM
G-SharK's Avatar
G-SharK
Just take the fuse out of the fuse socket and put the wire in and put the fuse back in place. Every simple and if does not work for you, just remove it and put everything back to stock.
Old May 24, 2012 | 09:30 AM
randomwalk's Avatar
randomwalk
dang this is harder than I thought. The fuse is actually a micro fuse that has no leg...kind of impossible to tap into especially when it's so tiny. All wiring on the LS is so hidden too...
Old May 24, 2012 | 09:42 AM
randomwalk's Avatar
randomwalk
forget it..I'll just tap into the fog light wire and turn it on with headlight (on auto). When ever headlight is on, fog is on and I'll get my signal
Old May 25, 2012 | 07:33 AM
G-SharK's Avatar
G-SharK
What are you trying to install? I tap my DRL to the ignition fuse in the fuse box. So when the car is on, the lights come on.
Old May 25, 2012 | 07:56 AM
CJITTY's Avatar
CJITTY
Random..what you cookin up man?
marshall2j
Aug 1, 2025 03:24 PM
knyg
Sep 2, 2017 10:30 AM
socaligs
Feb 1, 2017 10:31 PM
ATP123
Sep 6, 2014 12:03 PM
sitinon20s
Nov 30, 2012 12:41 PM
