HELP Data Systems air Suspension Controller Problem
Old Feb 11, 2012 | 12:43 PM
yodanadane's Avatar
yodanadane
Default HELP Data Systems air Suspension Controller Problem
Has anyone had any experience with different height levels of there vehicle? I bought my car and installed the system roughly 2 months ago all was good. However Here is my issue . Yesterday i walked out to my car and the passenger side looked lower than normal, I looked at the drivers side and it looked ok . The level it was set as was front 4 rear 3 , I took out a tape measure and measured in my garage from the floor to the top of the opening in the wheel well. There is a difference of roughly 3/8 of a inch. When i set the controler to the normal level there is still a difference but only slightly more than a 1/8 of a inch. In order to have all four wheels at the same level The dfrivers front is at 4 passenger front 2 rear at 3 . however the passenger rear is still about a 1/4 lower. Do i need to reset controller? Uninstall and reinstall? Or just live with it?
Thanks
Old Feb 11, 2012 | 03:59 PM
Nat's Avatar
Nat
Make sure the floor is level. You can never get it to be even...mine is always off by a few mm. I'be learned to live with it. I read somewhere even cars at the dealer have the same condition.
Old Feb 11, 2012 | 11:20 PM
rominl's Avatar
rominl
exclusive matchup
definitely first make sure the car is on a level ground.
for lexus cars, left and right is never the same height (ask lexus why), same thing on my ls460l, the right side was always lower by more than 1/2 inch.
Old Feb 12, 2012 | 06:36 AM
CJITTY's Avatar
CJITTY
Does the difference have anything to do with compensating for driver weight if left side is typically higher than right? Can you get someone to re-measure with you sitting in the car?
Old Feb 12, 2012 | 05:27 PM
yodanadane's Avatar
yodanadane
Thanks
Sounds like this may be common .
Old Feb 12, 2012 | 08:52 PM
Nat's Avatar
Nat
Dana, you can balance it out. I have mine set at 6 front right and 5 front left...6 at rear. This balance out pretty well for me.
Old Feb 13, 2012 | 08:03 PM
yodanadane's Avatar
yodanadane
Thanks Nat, Wow your riding low at level 6.
Nauticalx
May 3, 2026 10:36 PM
quick123
Jul 18, 2013 05:42 PM
RACEREDI
Jan 9, 2012 05:34 PM
mrcd
May 2, 2011 02:20 PM
hatteroo
Apr 27, 2011 06:10 AM
