Wheels fitments question?
Subscribe
Oct 30, 2011 | 05:55 PM
I found this wheels on sale on BMW forum, can it fit on LS460?? below is the link
http://e60.5post.com/forums/showthread.php?t=598383
Reply 0
Oct 30, 2011 | 08:14 PM
i don't think so. the bolt patern on the ls is 120x5 bmw's are 112x5 i think. plus they are too small.
Reply 0
Oct 30, 2011 | 08:22 PM
they are small but bimmers and some benz run 5 x 120
Reply 0
Oct 30, 2011 | 11:17 PM
they will work from a bolt pattern and diameter/width perspective (if you wanted an oem +1 fitment), but the offsets are too aggressive to make them worthwhile. i'd pass.
Reply 0
Oct 31, 2011 | 06:05 AM
Quote: I found this wheels on sale on BMW forum, can it fit on LS460?? below is the link
What "kills" most Kewl wheel choices when considering them for our beloved LS460's is the unusual LS460' "5 x 120" bolt pattern.
This information came from two of America's premier wheel merchants.
Best Wishes to all ........
Mikey Lulejian
Lake Oconee, GA
Reply 0
Oct 31, 2011 | 06:43 AM
Mikey Lulejian
Lake Oconee, GA
BMW, range rover, rolls royce, etc. are all 5x120 -- that bolt pattern is by no means unusual :P. we can also run wheels off of certain camaro/corvettes (as well as other related GM products) too. the bolt pattern isn't really an issue (you can have the wheels sleeved and redrilled for maybe $15-25/wheel), it's the other specs -- offset, width, and diameter are more important in figuring out whether the wheels will fit or not.
Reply 0
Oct 31, 2011 | 10:21 AM
Quote: BMW, range rover, rolls royce, etc. are all 5x120 -- that bolt pattern is by no means unusual :P. we can also run wheels off of certain camaro/corvettes (as well as other related GM products) too. the bolt pattern isn't really an issue (you can have the wheels sleeved and redrilled for maybe $15-25/wheel), it's the other specs -- offset, width, and diameter are more important in figuring out whether the wheels will fit or not.
What is the best offset for LS460?? and what's on the OEM rims?
Reply 0
Oct 31, 2011 | 11:53 AM
Quote: What is the best offset for LS460?? and what's on the OEM rims?
See these offsets at
http://www.advantiwheel.com/specs/al...100_black.html
Stock offset is 32mm
Reply 0
Oct 31, 2011 | 06:41 PM
those wheels are clean and a little bit different because of the center cap, +1 if there multi piece...
Reply 0
Oct 31, 2011 | 08:56 PM
Quote: those wheels are clean and a little bit different because of the center cap, +1 if there multi piece...
they are multipiece, but i'm not sure if they're a welded 3pc like some trafficstars are. altstadt/trafficstar is a quality wheel
Reply 0
Nov 1, 2011 | 09:21 AM
those wheels will not fit on the LS460 without fender modification.
Quote: What "kills" most Kewl wheel choices when considering them for our beloved LS460's is the unusual LS460' "5 x 120" bolt pattern.
I actually find that statement to be entirely misleading. BMW wheels are all 5x120 and I've never heard a complaint about their wheel selection. As far as our classifieds section goes, sure, you'll have a harder time finding wheels there, but even the new Acura TL comes with a 5x120 bolt pattern.
There are a plethora of wheel choices that exist for our cars, you just need to find one that suits you.
Reply 0
Nov 1, 2011 | 02:43 PM
My friend from tires shop just told me, our LS will need hub rings from 60.1 change to 72.5 to get fit BMW wheels
Reply 0
Nov 1, 2011 | 04:35 PM
Quote: those wheels will not fit on the LS460 without fender modification.
I apologize for providing any information that may have been misconstrued as misleading.
It was not my intention whatsoever.
Best Wishes to all,
Mikey
Lake Oconee, GA
Reply 0
Nov 6, 2011 | 11:57 AM
Quote: My friend from tires shop just told me, our LS will need hub rings from 60.1 change to 72.5 to get fit BMW wheels
I agree, so we can put x5, 7 series wheels on ours right?
Reply 0
Nov 6, 2011 | 07:06 PM
Quote: I agree, so we can put x5, 7 series wheels on ours right?
no, the hub ring is only to make the wheel hubcentric again, not a magic cure all for wheel fitment. because of the aggressive offsets and widths that BMW runs on their X5/6 and 7-series, you probably WON'T be able to run those wheels UNLESS you're willing to do some fender modification (not cheap -- i'm talking about more than a simple roll) OR camber work (which is kind of a unicorn except for in japan and even more expensive than quality fender work).
synopsis: just because the wheel has the same lug pattern (5x120) as our cars doesn't mean the wheels will work (you have to take into consideration width, offset and tire selection also or be willing to do more serious modification to your LS)
Reply 0
Subscribe
