Instrument lights going crazy
Old 04-10-11, 10:13 AM
fteiii
fteiii's Avatar
Default Instrument lights going crazy
My instrument cluster occasionally goes nuts: check abs, check power steering, check vsc, tach bounces, all instrument lights come on and a strange diagnostic green screen comes up on the nav screen. Any ideas? My dealer can't seem to find the issue. Replugged connectors etc
fteiii is offline
Old 04-10-11, 01:50 PM
Shibumi1
Shibumi1's Avatar
sounds like its losing ignition.. did a 460 last week w remote start someone tied a radar system to the digital ign in the car.. because its the computer that creates true ignition for the car (push to start systems) u cant tie into it under the dash.. needs to come from cig lighter or a fused circuit in the car..
ex: the radar system had a 1amp fuse..(so it actually draws half that) and it was enough to stall the car..
Shibumi1 is offline
Old 04-10-11, 02:46 PM
Nospinzone
Nospinzone's Avatar
Have a load test done on your battery. If it's weak, that's probably the culprit.
Nospinzone is offline
Old 04-10-11, 07:39 PM
Shibumi1
Shibumi1's Avatar
i would have said that but he said the car already went to the dealer.. u would assume they would check the batt and charging system
Shibumi1 is offline
Old 04-10-11, 08:38 PM
fteiii
fteiii's Avatar
Default Thanks
No add on electronics and I'll check with my tech man tomorrow re the battery. This problem Was first noticed when braking hitting a pothole: all dash lights came on, tach and speedo zeroed (engine kept running). Did it again while breaking on a freeway detour going over reminder bumps. Lex checked all connectors and battery terminals. Still doing it but this time when I was starting car. Sounding more like battery. Thanks again
fteiii is offline
Old 04-11-11, 01:27 PM
Nospinzone
Nospinzone's Avatar
Shibumi1, I just read your first post carefully, are you a Lexus mechanic?
Based on fteiii's last post, I think you may be on the mark that it's an electronic issue (I realize its not an add-on problem).
Danieltm6
GX - 1st Gen (2004-2009)
02-15-21 03:43 PM
jonmonkey
RC - 1st Gen (2015-present)
03-12-19 09:38 AM
docweav23
05-20-16 06:51 PM
ns400h
Hybrid Technology
01-10-16 02:40 PM
guesswh0
10-08-15 10:35 AM
Quick Reply: Instrument lights going crazy
