need help continuous beep in my 460l
Old Jul 4, 2010 | 09:05 AM
joeLS460L's Avatar
joeLS460L
Default need help continuous beep in my 460l
i have no idea what this is.its loud ,steady, and annoying.came on at an intersection and now will not go off while the car is on.at all...can anyone help me
Old Jul 4, 2010 | 09:28 AM
JFNash's Avatar
JFNash
Is it like when you put the car in D or N and open the door?
Old Jul 4, 2010 | 09:40 AM
cmasten's Avatar
cmasten
do you fasten your seat belts when you drive? any indicators activated on the dash that you maybe havent noticed? I had a similar situtation in a GS I owned, turned out to be a low battery in the remote. Hopefully its something simple. It may also be worth a shot to pull out the manual and see if it speaks to this situation and under what conditions it exists.
Old Jul 4, 2010 | 09:41 AM
joeLS460L's Avatar
joeLS460L
no all the time..park,drive,reverse, its always on..everything in the car works except the radio..the navi still works just wont speak..the beeping seems to be coming from the speakers and just cancels out anything else.i cant turn it down..the cd player will stil lplay cds even just wont come through the speakers
Old Jul 4, 2010 | 09:51 AM
joeLS460L's Avatar
joeLS460L
seems to be almost like an alarm of some sort but i have no idea.i tried deleting the schedualed maintenance but that didnt do anything.i was thinking about disconnecting the battery but its all pack up in the bay it doesnt look exactly easy to get to
Old Jul 4, 2010 | 09:57 AM
jmcraney's Avatar
jmcraney
You should look at your dash display for some indication of an alarm condition. If there is no indication on the dash display it might be some sort of defect with the audio system. You might have to remove the audio amp fuse to silence it until you can get to a dealer.
Old Jul 4, 2010 | 09:59 AM
Dave Mac's Avatar
Dave Mac
You didn't damage a parking sensor in some way did you?
Dave Mac
Old Jul 4, 2010 | 01:23 PM
VA380's Avatar
VA380
Hey bro, your amp blew out ... happened to me a few weeks ago. They have to disconnect the amp which will make the noise stop. Takes about 3-5 days for the part to be ordered ... if you are still under warranty it's free.
Old Jul 4, 2010 | 02:09 PM
cmasten's Avatar
cmasten
lol.. yea your amp blew, guess we needed more info from you to help :-)
Old Jul 4, 2010 | 03:39 PM
joeLS460L's Avatar
joeLS460L
ohh thank you..where is the amp located so i can disconnect it?
Old Jul 5, 2010 | 10:41 AM
jbuffett's Avatar
jbuffett
I bought an '07 CPO on Friday, while doing sale prep they told me that the car was making this same beeping sound and that the amp needed to be replaced. I wonder how common of a problem this is, and whether or not the new/replacement ones are any more reliable? I'm getting them to do the window / wind-noise TSB anyway so they were already going to be keeping it a few days anyway.
Old Jul 5, 2010 | 02:19 PM
cmasten's Avatar
cmasten
the amp is located under the right rear panel in the trunk. There is one bolt to take out to get the side flap off its under the loop on the right side towards the rear seat. Once that is out then the flap just comes out and the amp will be seen inside the wheel well area in the corner. There are some bolts that hold the amp down and the connectors are all on the outside wall towards the fender.
If the sound is driving you nuts, then just pull the fuse for the amp under the kick panel, its the manual its a larger fuse, I cant remember if its on the driver or passenger side, but it clearly shows it in the manual for the vehicle that will kill the power to it and stop the noise until they can get it replaced.
mohdr47r6
Oct 15, 2014 05:23 PM
zgxl04
Feb 6, 2009 05:59 PM
turbosix
Nov 6, 2006 08:23 AM
kglexus1
Jul 20, 2006 07:55 PM
sc4009688
Nov 3, 2005 08:59 AM
