Strange air conditioning problem
Old Jun 15, 2012 | 11:58 AM
OSU's Avatar
OSU
Originally Posted by Edcentury
I replaced the cabin filter without using the dash recycle modes. By doing this a small bracket came off and the computer thought that no filter was in the car and set the car to 75 degrees by default. You could turn the air on manually but not automatic. The cure is to reattached the bracket inside the cabin filter door.
How do you do that?
Old Dec 29, 2012 | 04:08 AM
bschleg2's Avatar
bschleg2
Default Air conditioning problem
When I restart my 2008 460l I get a clicking noise behind the glove box and while this happens you cannot work any functions of the ac/heat. After about 1-2 minutes The a/c shows an off sign and then it can be turned on and is set at 75 degrees.It does not matter ifyou turn off system before you shut off car. After the car is cut off you may hear the noise and it may repeat itself . I would think this would be some sort of blend door problem.
Old Dec 29, 2012 | 05:57 AM
CJITTY's Avatar
CJITTY
Originally Posted by bschleg2
When I restart my 208 460l I get a clicking noise behind the glove box and while this happens you cannot work any functions of the ac/heat. After about 1-2 minutes The a/c shows an off sign and then it can be turned on and is set at 75 degrees.It does not matter ifyou turn off system before you shut off car. After the car is cut off you may hear the noise and it may repeat itself . I would think this would be some sort of blend door problem.
Wow..this thread is from 2008!!
Sounds like your cabin air filter mechanism is faulty. I wonder if the filter was changed at one point and they didnt follow the proper steps
Old May 8, 2015 | 04:16 AM
rickster9's Avatar
rickster9
Question Shut off AC before leaving car?
In the old days you'd shut off the a/c before you leave the car. Is this still the case?
Old May 10, 2015 | 04:41 PM
roadfrog's Avatar
roadfrog
no.........
Old Jun 25, 2015 | 03:53 PM
Rufio808's Avatar
Rufio808
Originally Posted by exBMWowner
I'm having a very strange problem with my air conditioning unit that the dealer has never seen before. Each time I start up the car, the air conditioner initially fails to turn on. It seems to try to start up for about a minute. The green A/C light comes on, but no air blows out. Then, after about a minute, a message shows up on the nav screen saying "Air Conditioner off". The green light also turns off.
If I then press the A/C button again, the green light comes on, and after about 15 seconds, the air starts to blow and the unit appears to be fine.
This process happens consistently, each and every time I start up the car. The only time it may not go through this cycle is if I just turned the car off within the last few minutes and then start it up again, in which case the air conditioning seems to work fine.
I suspect when I went to the dealer, they did not pay much attention to what was happening the first time they started the car, and then on each successive restart, the symptom failed to reappear because the A/C unit seems to start fine if it was just running within the last few minutes. The dealer says they have never seen this before and was unable to solve the problem.
Has anyone else seen this, or have any idea what might be going on?
Having a similar problem in my 2013 GS350 F-Sport..
After the car has been sitting overnight. I turn the car on in the morning, and the A/C is off and all my temp settings are back to 75° and the fan is off.....
I know it's not LS related, but any help is greatly appreciated!
Old Sep 24, 2015 | 09:01 AM
xmasparty's Avatar
xmasparty
I have a 2007 is350 that is blowing hot air out of the rear vents attached to the center console when the AC is on and both the left and right vents in the front are blowing ice cold air as they should.
Old Apr 5, 2017 | 05:23 PM
joedaddy1's Avatar
joedaddy1
same issue for me.. what's the fix? ::
Old Apr 5, 2017 | 05:36 PM
Lexuslsguy's Avatar
Lexuslsguy
What the fix? Take to auto mechanic and have inspected...
Old Apr 5, 2017 | 05:39 PM
joedaddy1's Avatar
joedaddy1
uhhhhhhhhhhhhhhhhhhhhhhhhhhhh.... thanks?
Old Jul 5, 2018 | 12:01 AM
Lexuscj's Avatar
Lexuscj
Same thing was happening to me after I changed my a/c filter after reading on the internet I took my filter back out and made sure I put everything back in correctly since then I haven't had the problem it was an easy fix glad it didn't cost any money
Old Jul 5, 2018 | 12:07 AM
Lexuscj's Avatar
Lexuscj
Same thing happened to me after I changed my a/c filter after reading on the internet I removed my filter and made sure that I put everything back in correctly it was an easy fix glad it didn't cost any money
ejm3
RX - 3rd Gen (2010-2015)
52
Jan 28, 2015 12:46 PM
MJA1951
Jun 28, 2014 07:48 AM
MJA1951
Jun 3, 2014 05:15 AM
icegoffy
Hybrid Technology
May 30, 2011 12:59 AM
nbatliwall
GS - 1st Gen (1993-1997)
Sep 16, 2008 09:48 AM
