I spilled some coffee on my carpet and took immediately to the car wash. I was there within 2 minutes. They could not get the stain out! Anyone else had this problem and does anyone have a solution? The car wash manager was amazed that he could not remove the stain.
I don't know what the car wash guy used, but I almost always have good luck with Glass Plus™ window cleaner. (Yep, you read that right!)
I use GP on carpet stains at home and in the car, and it has taken care of most "ordinary" stains ... Of course, I wouldn't expect it to remove tar or heavy grease, etc.
Spray it on the stain until it's completely damp, then use your fingertips or a small brush to work up a lather, going in all directions so you scrub every side of the carpet fibers. Then, take a dry white cloth and scrub it hard, again going in all directions. It will dry in an hour or so in most cases.
Don't use Windex™ or any other cleaner that may contain ammonia.
I'm afraid your only option is to replace the carpet. Coffee stains will not come out, at least not to a perfectionist's satisfaction (i.e., the stain may come out, but the carpet will be discolored in the process).
Home Depot carries a carpet cleaner called "FOLEX", it is the best I have used. I have tried many different carpet cleaner before, Folex is the best. I used it on my LS460, my home, everytime is sucess.
Spary lots of it on the stain until wet, work the stain out with your finger in all direction, dry the spot with paper tower.
Spot Shot is available many places and I have removed heavy axle grease and oil based wood stain spills from carpet with no problem - PM me if you cannot locate it, it is the best
First calm down. Next, drive to the dealer. Next tell the detailer to deal with it and get it out. That is my simple solution. He will get most if not all of it out. They have all kinds of special potions and lotions that we don't have in the market. Give it a try. Good luck.
