Let me know if you could get one or not because im interested in that TIS.
It can do many things if you check the last few pages in the manual, Customizable Features. You are able to do many changes with door settings for instance.
1-Wirelss remote control:
Unlocking operation: The deafult is set to Driver's Door unlocked in one step, all doors unlocked in two steps i want to use the cutomized settings which is all doors unlocked in one step which i shall say default for your cars.
2-Door lock:
Opening Drivers's door unlocks all doors:is set to off i want to enable this function
3-Door lock:
Unlocking using a key:again Driver's Door unlocked in one step, all doors unlocked in two steps i want to use the cutomized settings which is all doors unlocked in one step which i shall say default for your cars.
4-When the gear is shifted to "P" unlock all doors (ON/OFF).
5-When the gear is shifted from "P" lock all doors (ON/OFF).
6-Volume beep when the remote is out of the car(Increase/Decrease).
Removing the seat belt alarm Chime/Buzzer when the gear is shifted to "D".and when the car is ready to take off. Disabling that will also disable the sensor on the passeneger seat to work everytime a passeneger gets up and down.
Illumination , light controls, Warnings, and much more. These are "some" of the settings i remember. i hope i make sense to you.
already checked buddy the programble ones that i found is just one:
Hold the memory seat button 1,2 or 3 and with pressing the "Unlock" button on the wireless remote control, With the door closed, untill you hear a beep. This will actually call back the wanted position everytime you unlock the door(if it was changed).
To cancell hold the set button pressing the "Unlock" button on the wireless remote control untill you hear a beep.
Customizable features that can be done by yourself are limited. The TIS computer has zillions of configurations.
You can program the doors to lock and unlock depending on vehicle speed (eg. lock when you start driving) or shifter position (eg lock when shifting to D)
This is definitely possible in the US cars. All this can be done without computer programming equipment.
how i wanna do it??
--but
i heard you HAVE TO bring it to the dealer dfor thatt
