LS 460 L using Bluetooth question
Old Aug 2, 2007 | 10:19 PM
uae's Avatar
uae
Default LS 460 L using Bluetooth question
Hello guys ive noticed something while using the handsfree now lets say my bluetooth is connected to the car and someone calls and i have friends with me in the car so i decide to make that conversation private by turning off the bluetooth from My phone now im using the phone again either with my hands or headphones. Conversation is now over and i want the bluetooth to be set again to handsfree so i turn on my bluetooth but didnt work , i tuned off my phone and back on but it didnt work. I stopped the car and doing the following in my touch screen :
Info-> Bluetooth -> Settings -> Bluetooth -> Register - > and using my phone and searching for the cars bluetooth i manged to connect again.
Is there any hack to connect to the car bluetooth while im driving and having no problems at all turning the phone's bluetooth ON/OFF without stopping the car ?
Old Aug 2, 2007 | 10:24 PM
350Dave's Avatar
350Dave
I use the 'transfer call' button on the nav screen. That is what it is designed for. Alternately, a couple of times my phone has lost pairing while driving. I have only needed to switch the BT off and then right back on again at the phone, and I have reconnected every time without even stopping. I hope that helps.
Old Aug 2, 2007 | 10:28 PM
uae's Avatar
uae
Thanx for the quick feedback ill try hitting that button ill go try it now and post back again.
Old Aug 2, 2007 | 10:43 PM
uae's Avatar
uae
Thanx a million + a Million More , first i thought the car doesnt support this feature its been like i month and i was starting to hate it.I never thought of that button your post was very helpful
Old Aug 4, 2007 | 09:56 PM
Scrappy's Avatar
Scrappy
My Call Transfer button is greyed out while I am moving. Is that normal? Is it a setting that my dealer can change?
Old Aug 4, 2007 | 11:19 PM
uae's Avatar
uae
When i tried pushing the "Transfer" button the car was at rest and it was not greyed out. Yesterday i was driving my car and had the same issue the button was greyed out, check your phone you will see a button named handset when you push it it will disconnect from the handsfree. To set it back to handsfree is to look at the same place where you hit the handset button you will see bluetooth push it or if you end the call in handset mode the next call automatically will be set to handsfree, tried it yesterday hope this helps
*My phone is N95
This is a pic from the internet Both buttons will replace "Music Player"
-Handset
-Bluetooth
depending on your choice.
I'll post a snap from my phone later. with both options
Old Aug 5, 2007 | 02:13 AM
uae's Avatar
uae
If the car is at rest you may use the transfer button if your moving the only way to get around it is using the phone.
I hope it makes sense to you now bro ..
Old May 17, 2012 | 11:21 AM
lcril522's Avatar
lcril522
Default Transer Call does not work while moviing
Is this true? The Transfer call button is "greyed" out while the car is moving? If so, I really don't like that. They will force you to look at your phone, find your bluetooth screen, then disconnect the bluetooth. That can't be safe. Almost like texting while you drive. Why not allow me to use the large screen in my car and hit one button?
I got a new Lexus LS in January. It has been driving me nuts when I am driving and my "transfer call" button is not enabled. I guess I now know why. Why would they design it this way?
Johnhav430
Oct 18, 2017 11:42 AM
EricTsang
Sep 25, 2011 12:00 PM
dk0515
Feb 13, 2008 08:02 PM
emjay
Feb 5, 2007 02:50 PM
MJMeucci
Oct 2, 2006 01:21 PM
