Sudden ABS, Trac, Brake Hold, Headlight, and even more errors
Old Jan 7, 2026 | 05:59 PM
mordyt's Avatar
mordyt
Default Sudden ABS, Trac, Brake Hold, Headlight, and even more errors
Hey all,
Looking for some thoughts as to what the root cause might be...
2013 LS460L with 158k miles. Out of nowhere, while driving, suddenly the ABS and Trac lights came on (and warnings in the center of the dash). About 30 seconds later, headlight and BSM system also gave a warning. And a few minutes later, Brake Hold (which isn't even on) started warning. Cruise control disabled. Then, the lights went out the next day and came back later on in the day. I scanned the car with techstream and got the following:
ABS: C13AF (EPM System Malfunction) / C1464 (Front Speed Sensor RH Circuit) / U0100 (Lost Communication with ECM/PCM/EV "A")
BSM: C1A45 (Vehicle Speed Sensor)
AFS: B2415 (Vehicle Speed Sensor)
Cruise Control: C1A50 (Brake System)
Electronic Parking Brake: U100
Ok, so maybe a wheel speed sensor, fine.... but then the lights went back out for a day or 2 on their own (no code reset).... and tonight, again out of nowhere, while driving....
Check Headlight, Check Parking Brake System with ABS and Trac lights.... and a new light - not the triangle master warning light (that also came on), but the circular warning light (this did not come on the first time). And then the Speedometer, Tachometer, and Temp gauges just went to 0. Then the gauges came back, died a second time, came back a second time and I was home.
I have to imagine a much bigger underlying cause then everything deciding at once to die. I'm hoping someone here looks at the massive list of codes and systems and says "ah yes, this 1 thing can trigger all of this" because right now, all I can think of is a computer or wiring issue.
Thoughts?
Old Jan 9, 2026 | 02:45 AM
Protholl's Avatar
Protholl
Check your grounds. Bat + to Bat -, Bat + to Engine block, Bat + to firewall
Old Jan 10, 2026 | 07:48 AM
Dean2's Avatar
Dean2
Most likely cause is battery near end of life or grounds. Test the battery with a proper toaster style tester. The digital tester most places use often says battery is good when it isn't. About $20 at
Harbor Freight or Amazon.Electronic Specialties 6 and 12 Volt Battery Load Tester Toaster Style - EL700 - Penn Tool Co., Inc
pokcie
Apr 2, 2025 10:26 AM
Saadq12
Oct 30, 2022 06:23 PM
dannyboylx
Mar 29, 2019 09:01 PM
chungmeow
Sep 25, 2015 11:48 PM
Jace_91
May 14, 2009 03:13 PM
