Suspension noise back
Old Dec 25, 2025 | 05:54 AM
2011LS460awd's Avatar
2011LS460awd
Default Suspension noise back
So after replace all 4 front lower control arms, inner and outer tie rods, ball joints and sway bar links my clicking/clunking noise is back on drivers side. Put it on lift with mechanic friend and went over everything possible to find the loose component etc. upper control arms still look great no play at all. Anybody else have an issue like this? I’m wondering if the beck and arnley control arms failed on one side but they seemed fine. Axels? Any help would be greatly appreciated or if you have any ideas I don’t wanna start replacing things on a wild hunch.
happy holidays.
Old Dec 25, 2025 | 07:43 AM
Gerf's Avatar
Gerf
Some aftermarket parts are bad right out of the box and that could be the case but by the number of parts you've changed I think you were already working on a bit of a hunch. If you're not sure if the part about to be changed is going to fix the issue then you should spend more time on diagnosis.
Old Dec 25, 2025 | 07:52 AM
2011LS460awd
makes sense. Lower controls were bad when I bought car. I changed myself. When I went to get aligned mechanic said other parts an issue so we changed than. Noise went away for about a month when I installed all that now that I think about what you said. Maybe one of the lowers was factory bad. I used moog sway bar links. They have a grease port, but I didn’t grease them because I’m assuming they were grease with factory, but maybe I coul try that.
Old Dec 25, 2025 | 12:58 PM
Anfanger's Avatar
Anfanger
You didn't specify in what conditions you can hear the noise.
Old Dec 25, 2025 | 01:11 PM
2011LS460awd
driver side. Little bumps, never on highway. If I push down on car or use a bar under it I cannot mimick the noise.
Old Dec 25, 2025 | 01:41 PM
Anfanger's Avatar
Anfanger
If you open the driver side window, can you hear clunking?
Old Dec 25, 2025 | 02:25 PM
2011LS460awd
I will check that tomorrow and post results. Thank you.
Old Dec 25, 2025 | 03:14 PM
Anfanger's Avatar
Anfanger
I had issue with Beck and Arnley where bushings looked OK but I had a suspension noise, especially, when it was colder outside. Then got progressively worse. Replacing lower control arms has resolved that.
Old Dec 25, 2025 | 03:25 PM
2011LS460awd
interesting. Well im in New York and it’s winter. All my front end was done about 1000 miles ago. And maybe I did start hearing the noise when it got colder. That would be absurd, though if that’s the case. What brand did you end up going with?
Old Dec 26, 2025 | 07:11 AM
Anfanger's Avatar
Anfanger
I used the same brand because of the price. Front lower arms would last from a few months up to 12 months (10k-12k miles).
Old Dec 26, 2025 | 12:07 PM
I'm well past 30k miles on Delphi arms and I don't drive gentle, no issues thus far but I did do all 8.
Old Jan 7, 2026 | 10:28 PM
Zetascry's Avatar
Zetascry
What noise is it? I’m in a similar situation. I’ve done the entire front end with oem parts. I suspect it to be the sway bar bushings, that’s only thing I haven’t changed.
Old Jan 8, 2026 | 02:36 AM
2011LS460awd
Ok. It doesn’t make noise when I have window open.
it’s hard to describe but maybe it is bushings from cold weather. Just saying this not sure if I’m correct but when driving when I have my left foot flat on mat towards the rear I “feel” it almost when I hit a bump and noise comes
Still snow here so when clears I will jack and grease sway bar links but possible my drivers rearward failed already. I’m wondering when I got it aligned if they didn’t tighten down at ride height when was on lift. I took a bar and I don’t have any movement on that bushing etc so I’m kind of stumped.
Old Jan 8, 2026 | 02:51 PM
Anfanger's Avatar
Anfanger
I would guess, it is caused by the failed front lower rear arm.
Old Feb 26, 2026 | 06:08 PM
2011LS460awd
Well just ordered new control arms. Going to replace both on drivers side and see if noise goes away. I do not hear it with windows down but I feel it under my left foot when hit bumps. Bushing doesn’t look bad have to get car on a lift to really be vigilant. I’m hoping maybe I could just tighten it at ride height and it will go away. Does anybody have the torque specs on those bolts?
