I'm planning to install an AGM battery in my 2007 LS460. The AGM battery requires a higher charging voltage. Based on Google search, the common solution is to replace the fuse with a diode so that the alternator (regulator) senses a lower voltage than what it really is. Then the alternator will output higher voltage (about 0.7V higher) that the AGM battery requires.
Anyone know which fuse I should replace on a 2007 LS460? It seems to be the fuse #15 in the engine compartment. But I'm not sure. Thank you!
I asked Perplexity AI if alternator output voltage boost was needed for agm batteries for 2007 ls460. What it said is copy/pasted below. Take it for what it's worth:
"For a 2007 Lexus LS460 using an AGM battery, boosting the alternator output voltage is generally recommended to optimize the battery's lifespan and performance, but it's not strictly required for the car to function. Factory alternator settings for most Toyota and Lexus vehicles, including the LS460, typically maintain charging voltages in the 13.8–14.2 volt range, which is adequate for conventional flooded lead-acid batteries but below the ideal charging voltage for AGM chemistry (approximately 14.4–14.8 volts)."
Why would you want an AGM battery in the first place? Just curious. The first time they discharge completely (dome light left on) they're generally toast from what I've read.
You do not need to do anything to your alternator or fuse or anything, the alternator has a voltage regulator built into it that limits the maximum voltage the alternator makes, but AGM battery is going to just be a 12V, same as the lead acid battery. You don’t need to change anything, I am not sure where you got that info, but it is totally wrong
Thank you for the input. You're correct - I don't HAVE TO do anything. My car will still run with an AGM battery without any modification. However it is not optimal. For traditional Flooded Lead-Acid (FLA) batteries, the charging voltage is 13.8-14.2. For AGM or lithium battery, the optional charging voltage is 14.5-14.9v. Without modification, the AGM battery will be undercharged and potentially shorten the lifespan. If you google "alternator voltage booster", you'll see a lot of products, from commercialized to DIY to trick the alternator.
I don't want to get into the debate of "why you want a AGM battery the first place" or "is it necessary to use a higher voltage to charge AGM battery", or "this is a stupid thing to do". I just want to identify the place to insert the diode so that the charging system (computer) believe the voltage is too low, thus output a higher voltage. Fuse #8(E/G RM-IG1-1) and #15(ECU-IG) are the ones I'm looking at. If anyone is familiar with alternator wiring and willing to share their knowledge, I'd appreciate it. Thank you!
To be clear you need a diode AND fuse in series not just a diode. Will have to be a seriously heavy duty diode as well. Once you get the hardware easy enough to experiment start swapping fuses one by one.
I know you don't want to discuss AGM, but my experience with them has been bad I'll never buy one again.
Thank you! It looks like on the newer models, there is a dedicated fuse in "sensor wire". In that case, many people just use a 12135037 mini-fuse shape diode(rated at 1A) with success. I get your point, if the wire is not just for sensor, it has load more than 1A, I'll need a diode rated accordingly. Then I'll have to go to DIY route and solder a 10A diode to a fuse. I'm just curious if the 2007 LS460 has a sensor wire for the alternator voltage.
From Grok, apologies for the poorly formatted text. Jump to the bold text if you just want to know about the mod.
The alternator and charging system on the 2007 Lexus LS460 (equipped with the 4.6L 1UR-FSE V8 engine) is a computer-controlled setup designed for efficiency, fuel economy, and battery longevity. It's a Denso unit (typically rated at 130-150 amps) that integrates with the vehicle's electrical architecture to provide variable voltage output rather than a fixed rate like older systems. Here's a breakdown of how it operates:Key Components
Alternator: Belt-driven by the engine crankshaft, it generates AC power, which is rectified to DC to charge the battery and power electrical loads. It includes an internal rectifier bridge, rotor/field coil, and a voltage regulator.
Battery: Original spec is a Group 24R flooded lead-acid battery (though AGM upgrades are common and compatible).
Sense Line (Voltage Sensing Wire): A dedicated wire (often green in the alternator's 4-pin connector) that monitors actual battery voltage and feeds it back to the system for regulation. This is not the main power output but a feedback loop.
Ignition Wire: Another wire (also green in the connector, fused with a 10A alternator fuse) that provides battery voltage to energize the alternator when the ignition is on.
Control Wire: A signal wire (blue/red stripe in some diagrams) from the engine control module (ECM) that modulates the alternator's field current to adjust output voltage.
ECM (Engine Control Module): The "brain" that oversees the entire system.
How It Works Step-by-Step
Excitation and Startup: When the ignition is turned on, the ignition wire supplies ~12V to the alternator's L (lamp) terminal, exciting the field coil. Once the engine starts (and the alternator spins above ~650 RPM), it begins generating power, sending a signal back through the L terminal to turn off the battery warning light on the dash.
Voltage Regulation: The system uses ECM-controlled variable voltage regulation (often called "intelligent charging" in Toyota/Lexus literature). The ECM receives inputs from:
Battery voltage via the sense line.
Battery temperature sensor (if equipped).
Engine load, RPM, and electrical demands (e.g., headlights, AC).
Battery state-of-charge (SOC) estimates based on driving patterns.
The ECM then sends a PWM (pulse-width modulated) duty cycle signal (11-14V range) via the control wire to the alternator's regulator. This adjusts the field coil current:
Low Demand Mode: At idle or light loads, output drops to ~12.5-13.5V to reduce engine drag and improve MPG. The ECM may even briefly cut charging to prioritize fuel efficiency.
High Demand Mode: Under heavy electrical load or low SOC, it ramps up to 14.0-14.7V.
Target range: Typically 13.5-14.4V at the battery terminals under normal conditions, but the ECM caps it to prevent overcharging (e.g., above 14.7V could trigger faults).
Feedback Loop: The sense line continuously reports battery voltage to the ECM. If it detects low voltage, the ECM increases field duty cycle for higher output. If voltage is high (full battery), it reduces output to avoid gassing or damage.
Safety and Monitoring: The ECM monitors for faults like over/under-voltage, opens circuits, or regulator issues. Faults trigger the "Check Generator" or battery light, and it may log DTCs (e.g., P1630 for alternator control circuit). The system also integrates with the battery control module (if present) for hybrid-like efficiency features.
Output Flow: Generated DC power flows from the alternator's B+ terminal through a fusible link (140A main fuse in the engine bay) to the battery positive terminal, splitting to power loads and recharge the battery.
This setup differs from traditional alternators with standalone regulators—here, the ECM dynamically optimizes charging to extend battery life and reduce parasitic drag (up to 5-10% MPG gain).Regarding the Diode Mod on the Sense LineYes, the clublexus.com user (in a similar thread for the GX460, which shares the same Toyota/Lexus platform and Denso alternator architecture) is proposing a common DIY hack for AGM batteries. AGM cells require a slightly higher sustained charge voltage (13.8-14.4V, ideally closer to 14.4V for full absorption) compared to flooded lead-acid (13.2-13.8V) to prevent sulfation, but the stock ECM targets the lower end for longevity.
How the Mod Works: Insert a silicon diode (e.g., 1N4001 or AC Delco equivalent, ~$4) in series with the sense line wire (the non-fused green wire in the alternator's 4-pin plug). Diodes have a forward voltage drop of ~0.6-0.7V. This makes the ECM "see" the battery voltage as 0.7V lower than actual (e.g., real 13.8V reads as 13.1V to the ECM), tricking it into commanding higher alternator output to "catch up." Post-install measurements in the thread showed ~0.5V gains (e.g., from 13.3V to 13.8V), stabilizing closer to AGM specs without overvolting the rest of the system.
Implementation Notes from the Thread:
Solder or crimp the diode inline, ideally with a small fuse (1-2A) for protection (diodes don't handle shorts well).
Alternatives discussed: Commercial boosters like HKBelectronics ($45, adjustable 0.5-1V boost) or Arclight ($60, with modes for reg/low/high boost), which avoid DIY risks.
Concerns: Potential ECM confusion if the drop isn't consistent (e.g., heat-affected), warranty voiding, or triggering faults if voltage spikes. One user suggested a battery tender for off-vehicle charging instead. It worked for the OP without issues, but YMMV—test voltages before/after at idle and highway speeds.
For the LS460 specifically, the wiring is identical to the GX in this regard, so it would apply directly—just confirm pinout via a multimeter (battery voltage on the fused green wire).
Thank you so much! The above bullet points are very helpful. There are 2 green wires in the regulator: #1 green wire is RLO. #2 green wire is IG (ignition). Based on the quote above, #1 is the sense line I'm looking for. I could inject the diode at the regulator 4-pin harness. But I was trying to find an easier way. So, the question is - is the RLO wire connected to any fuse at all? Goggle search gives different answers. Some said it is connected to the main (180A) alternator fuse in the engine compartment(bolt-on). Some it's connected to the 10A MPX-B fuse on the driver side under the dashboard.
Yep should be pin 1.
There isn't an easier way, will be harder to make a fuse/diode circuit.
Somewhere in the circuit chain is a fuse (actually more than one), this fuse will feed the ECU and a bunch of other things which means putting your diode inline with all those circuits is not practical.
I figured. The other models (like GX) have a dedicated ALT-S fuse ("S" stands for sense), which is a dedicated wire for the voltage feedback. With the ALT-S fuse, the diode hack is very easy as the fuse is usually at an easily accessible location (like the fuse box). The 2007 LS460 does not have a dedicated ATL-S fuse. The only way to inject the diode is to work on the regulator harness, which is not worth the hassle IMHO. For the not so handy persons, you may Google "Lexus alternator voltage boost harness". The cheapest one I found is $59 from Amazon.
I think I'll live with the stock alternator for now. Thank you all for your help!
